Date/Time: Sun, 27 Sep 2026 17:58:01 +0000
ColorBar drawing too small
View Count: 1032
[2015-12-15 21:59:59]
like2trade - Posts: 119
Please see the attached file link.
DrawStyle = point
Width/size = 1
The points are being drawn too small. Perhaps this is because it is being drawn so close to the header information. Is there a way to displace it a little more lower than the header?
Thank you.
http://www.sierrachart.com/image.php?l=1450216195784.png
[2015-12-15 22:01:26]
The study being used was not meant to be displayed in its own Chart Region. It needs to be displayed in Chart Region 1. This is how it was designed.
[2015-12-15 22:05:24]
Is there another study I can use that will work better to accomplish the same thing?
Thank you.
[2015-12-17 20:57:21]
One idea came to mind. Go to the study you have in Chart Region 2 and set the Draw Style for the Subgraph for it to "Background".
[2015-12-17 23:10:10]
Thank you very much Admin. That works very nicely.
http://www.sierrachart.com/image.php?l=145039372544.png
