Date/Time: Thu, 26 Dec 2024 23:13:00 +0000
Spreadsheet signals using ACSIL trading code
View Count: 1021
[2015-12-15 20:00:11] |
User856618 - Posts: 12 |
Hi- Is it possible to utilize existing spreadsheet system for trading signals (K + M Columns) while using variables for ACSIL trading? And is there example source code for this? -Thanks |
[2015-12-16 01:00:00] |
To be clear on this I have existing spreadsheet data inputted that put forth buy/sell entries based on that data. I would want to attach orders using Advanced Custom Study Interface and Language to allow for more customization around certain variables. Any advice where to look? |
[2015-12-17 04:11:25] |
Refer to the documentation here: https://www.sierrachart.com/index.php?page=doc/doc_ACSILProgrammingConcepts.html#ReferencingDataFromSpreadsheet Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-12-24 20:06:31] |
We do not know exactly what you are doing and how you are submitting the orders. But in general, set the Trade and Current Quote Symbol to that options symbol: http://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#TradeAndCurrentQuoteSymbol Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
