Date/Time: Thu, 26 Dec 2024 15:31:01 +0000
global chart dom settings
View Count: 753
[2015-12-15 13:31:28]
User20450 - Posts: 330
is there a way to set the chart dom different on one chart then another , i wanted the bid/ask depth on one chart but it put it on all of my charts with chart dom , i would like to be able to have it only on the one
thanks
[2015-12-15 18:12:57]
Yes. Have a look at the DOM Graph:
https://www.sierrachart.com/index.php?page=doc/doc_TradeMenu.html#DrawDOMGraph
With this you will not need to add the Bid/Ask Size columns to the Chart DOM.
Date Time Of Last Edit: 2015-12-15 18:13:05
[2015-12-15 18:30:23]
i know that one , but i want the bid and ask in the chart dom so i can see properly where bids and offers are , visually its better on the dom then on the chart
thanks
