Date/Time: Thu, 02 Jul 2026 09:42:36 +0000
chart on the top
View Count: 1361
| [2015-12-15 01:32:28] |
| User144295 - Posts: 76 |
Hi support time, Would you please help me to instruct me on how to set the floating chart always on top like the one on the screenshot? I would like to have the black little floating chart always on top of the blue background chart the way that if I click on the blue chart the black one stays on. I don't want black chart to disappear. Sorry I cannot attach screen directly from sierra since this is non sierra screenshot. Thank you |
| [2015-12-15 03:52:29] |
Follow the instructions here for this: Detaching and Attaching Chart Windows: Setting Detached Chart to Be Always on Top Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-01-04 00:22:08] |
Hi again Sierra team, I followed your advise and I set attached/detached window to be always visible using: Window >> Chart Window Always Visible However when I do this and after I click outside of this window (to be always visible) this window disappear in the background and it stops to be visible. I am trying to avoid "always on top" because I just wanted the desired window to be always visible within sierra charts only. Do you know if this is potentially possibly to achieve somehow? Thank you Branislav |
| [2016-01-04 01:25:57] |
The section we linked to is: Setting Detached Chart to Be Always on Top There is no other help we can provide. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-01-04 01:34:41] |
Detached or Attached, for me it is not really important. I just wanted to achieve the status when "always on top window" is on top within the sierra chart environment only. So for example, if I minimize sierra chart completely, that particular "always on top window" would go down as well as part of the sierra chart environment. Is it possible please? Thank you.
| [2016-01-04 03:13:06] |
You can do this if Global Settings >> General Settings >> Minimize/Restore Detached Windows with Main Window is enabled. Or just manually minimize that Always on Top window. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
