Date/Time: Thu, 17 Sep 2026 19:14:01 +0000
Drawing tools and studies on single time frame
View Count: 1022
[2015-12-14 18:24:36]
User487249 - Posts: 9
I am brand new but cannot figure this out and have tried searching the boards. I apologize if it has been answered elsewhere. Is there a way to draw a rectangle and have it displayed only on the time frame you drew it on? Or is the only option to have it displayed on all time frames? Also, the same for a study, can one be used only on specified time frames or will all studies show on all time frames?
Many thanks,
Daniel
[2015-12-14 18:56:55]
Chart Studies and Chart Drawings display on all-time frames on a chart.
There is no way to change this.
If that is what you require then Sierra Chart is not going to be appropriate for you.
