Date/Time: Thu, 26 Dec 2024 15:22:32 +0000
Dialog-Box
View Count: 704
[2015-12-14 10:29:43] |
User39772 - Posts: 311 |
Is it possible to attach a dialog box to an alert, so that the box pops if the alert triggers (e.g. in a window of a chartbook that is corrently not visible on the screen) ? |
[2015-12-14 18:41:32] |
What you can do is enable Global Settings >> General Settings >> General 2 >> Show Alerts Log on Study Alert. We assume you are referring to Study Alerts or an alert set in Chart Settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-12-14 19:20:07] |
Thanky you, that is exacttly what I need !
