Date/Time: Thu, 26 Dec 2024 15:52:44 +0000
Soybean oil data
View Count: 647
[2015-12-14 05:51:23] |
brown555 - Posts: 35 |
What happened to data? Using IB: http://www.sierrachart.com/image.php?l=1450072224200.png |
[2015-12-14 06:04:22] |
We are checking this now.
[2015-12-14 06:14:55] |
Update the Symbol Settings as explained here: http://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettingsSteps When that is done, go to the chart and select Chart >> Reload and Recalculate. If it is still not correct, then re-download the data following the instructions here: http://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html#ReDownloading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
