Date/Time: Thu, 26 Dec 2024 15:09:00 +0000
Post Rollover Position Display
View Count: 606
[2015-12-14 05:43:01] |
Roger Grace - Posts: 14 |
I note that after I performed the latest rollover, the position entry value line for executed orders does not show up on SC. Order lines are still OK. Please advise |
[2015-12-14 05:49:43] |
Do you see the Position Quantity on the Trade Window for the Chart/Trade DOM being traded from? We need to understand is the problem that the Position Quantity is incorrect or the Position Average Price is not correct? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-12-15 21:08:08] |
Upgrading to latest ver. 1336 seems to have fixed the problem.
