Date/Time: Thu, 26 Dec 2024 15:01:53 +0000
Changing chart windows
View Count: 797
[2015-12-13 06:39:17] |
User967815 - Posts: 9 |
Hi there I have looked through the support materials and may have missed it. Is there an option to restore a window size. Lets say I have four window arranged on my chartbook in a quadrant shape. After maximizing I am looking for an option to restore the window back to the original size in the quadrant (other using than the restore icon in the top right of the window which sometimes results in accidentally closing the window). Does this exist? Thanks |
[2015-12-13 11:13:11] |
Yes. It is Window >> Restore and you can set up a keyboard shortcut for that.
[2015-12-14 00:15:54] |
Thats great, many thanks!
