Date/Time: Thu, 26 Dec 2024 17:44:18 +0000
Dtc, OPEN_ORDERS_REQUEST doesn't return orders for sim
View Count: 930
[2015-12-12 20:45:40] |
T29_Dev1 - Posts: 22 |
Hi, I connect to SC in simulation mode and send OPEN_ORDERS_REQUEST packet. SC answers only one empty ORDER_UPDATE packet. I can see ORDER_UPDATE packets when I submit orders in SC but I can't request a list of orders. parameters for OPEN_ORDERS_REQUEST: RequestAllOrders = 1; ServerOrderID = ""; For CTS T4 it works fine. v.1338 |
[2015-12-12 22:47:28] |
This problem has been identified and resolved. We will put out a new release no later than tomorrow.
[2015-12-14 20:39:49] |
onnb - Posts: 662 |
In what build to expect this fix?
[2015-12-14 21:47:24] |
This will be out in version 1339 which we should have out before morning.
[2015-12-16 13:33:12] |
Should it work on 1339 version? It looks like OPEN_ORDERS_REQUEST is still not working.
[2015-12-16 19:11:48] |
We are checking on this now.
[2015-12-16 19:35:31] |
The problem is confirmed to be solved. We tested in version 1340. What did you set s_LogonRequest::TradeMode to? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-12-16 19:41:48] |
I set s_LogonRequest::TradeMode to TRADE_MODE_LIVE. With TRADE_MODE_SIMULATED it works. Thanks, the problem is solved. |
[2015-12-16 20:33:29] |
This is good. We knew that must have not been set correctly.
[2015-12-16 23:05:50] |
Curious what type of encoding you are using for DTC? Just wanting to know what others are finding useful.
[2015-12-17 16:43:44] |
We use binary encoding
