Date/Time: Sat, 12 Sep 2026 16:25:44 +0000
AMP data feed down on weekend?
View Count: 1221
| [2015-12-12 07:01:43] |
| tobi - Posts: 351 |
I've set up the AMP/TTNet data feed (data feed from AMP; direct account of SC) yesterday afternoon (EST time). All was working fine. Now I don't get a connection (please see part of the Message Log below). Is this normal (due to being saturday/weekend) or should I be able to connect and receive backfill data? AMP/TTNet | Connecting. | 2015-12-12 07:54:11 TT FIX Data | Connecting to 12.41.48.53. Port 10501 | 2015-12-12 07:54:11 TT FIX Data socket (28) | Error received in OnConnect while connecting. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2015-12-12 07:54:13 TT FIX Data socket (28) | Shutdown and closed. | 2015-12-12 07:54:13 TT FIX Data: Socket connection was closed without any logout messages sent or received. | 2015-12-12 07:54:13 TT FIX Data: Disconnected. | 2015-12-12 07:54:13 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-12 07:54:13 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-12 07:54:13 TT FIX Data: DisconnectFIX called. | 2015-12-12 07:54:13 TT FIX Trading: DisconnectFIX called. | 2015-12-12 07:54:13 AMP/TTNet | Disconnected. | 2015-12-12 07:54:13 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-12-12 07:54:13 File >> Disconnect selected. | 2015-12-12 07:54:17 TT FIX Data: DisconnectFIX called. | 2015-12-12 07:54:17 TT FIX Trading: DisconnectFIX called. | 2015-12-12 07:54:17 AMP/TTNet | Disconnected. | 2015-12-12 07:54:17 |
| [2015-12-12 07:33:36] |
| User13668 - Posts: 296 |
Not available in the weekend. It says so right here in the documentation/manual: https://www.sierrachart.com/index.php?page=doc/AMPTTNet.php#ServerAvailability Date Time Of Last Edit: 2015-12-12 07:33:48
| [2015-12-12 07:36:02] |
| tobi - Posts: 351 |
Thanks for the information User13668 :-)
