Date/Time: Thu, 26 Dec 2024 13:34:10 +0000
More sample trading systems?
View Count: 944
[2015-12-12 05:52:19] |
cazeek - Posts: 33 |
Hello, I've never coded before, and I've made a lot of progress today, but I am definitely struggling a bit. I already have my system rules tested manually, and I would really like to get everything set up for backtesting. Are there any more sample trading systems other than the one crossover listed in the documentation I can take a look at? I need to enter some advanced rules in, and it is tough only having the documentation to work from without more samples to look through. Thanks very much, Steven |
[2015-12-12 11:34:26] |
Yes, refer to: https://www.sierrachart.com/index.php?page=doc/doc_ACSILTrading.html#ExampleCode Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
