Date/Time: Sat, 12 Sep 2026 07:20:45 +0000
Historical Download Fail
View Count: 1083
[2015-12-11 18:39:11]
100 - Posts: 147
I can't download any intraday historical data. This is what I'm seeing.
Socket Connected
Sending historical data logon request message
DTC - Server protocol version 7. Client protocol Version 4. There is a protocol mismatch!
Error downloading historical intraday data for CLF6-Nymex. Historical data logon error: Invalid/missing data for service code: scbcd
Thank you! Let me know if you need more.
[2015-12-11 18:52:11]
That is not the correct symbol. Refer to this help topic about this:
https://www.sierrachart.com/index.php?page=doc/helpdetails3.html#h3.2
We see you are using the Sierra Chart Exchange Data Feed and you are using an older version of Sierra Chart. You need to update Sierra Chart to the current version:
https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate
[2015-12-11 19:06:11]
100 - Posts: 147
I'm Pretty sure that is the correct symbol.
Might it be related to a corrupted data file which I need to delete?
I had a similar problem a while back, which I have forgot how to deal with.
[2015-12-11 19:10:05]
That is a Rithmic symbol. It definitely is not correct.
You need to use the symbol CLF16
[2015-12-11 19:41:19]
100 - Posts: 147
Sorry ! Thank you.
Last question:
How do I fix this?
http://www.sierrachart.com/image.php?l=1449862798223.png
[2015-12-11 20:08:36]
This is a case of missing data. Follow the instructions here:
https://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html#ReDownloading
