Date/Time: Thu, 26 Dec 2024 13:10:53 +0000
Gene Sheldon
View Count: 776
[2015-12-11 13:28:36]
User72965 - Posts: 115
Last 2 time frames ??? uv??
Start on the 15 minute Instead of
waiting for the 1/2 hour time ??
Chart is supposed to change time frames on
the 1/2 hour. > 5:30 6:00 6:30 ect.
I'm getting need to roll symbol to march??
Think that's next week > we're trading Dec. yet....
I'll send a chart pcture ...
Thx Gene :)
http://www.sierrachart.com/image.php?l=1449840442637.png
v >> It's 6:27 now .. v started @ 6:15 thx ..
[2015-12-11 18:00:19]
We are not understanding this.
However, refer to this documentation here:
https://www.sierrachart.com/index.php?page=doc/doc_TPOVolProfileCharts.html#LetterCodes
https://www.sierrachart.com/index.php?page=doc/doc_TPOVolProfileCharts.html#SessionTimes
[2015-12-11 18:19:17]
The day session opened all right.
Right on 7:30 my time ......
I'll go to the doc. And see what I can.
I'm taking it you found nothing on my chart.
And I'm under the situation > That you can
open up the Studies & Global to see if all was
in order ???
Thx Gene :)
[2015-12-11 18:34:35]
To see if what is in order? We cannot see your Sierra Chart and it is up to you to set the settings as you require.
