Date/Time: Sat, 04 Jul 2026 12:05:03 +0000
custom spread
View Count: 1537
[2015-12-11 12:28:02]
User681584 - Posts: 4
How do I make a custom spread for eg.if i want to see the difference between 2 products say HO Jan 16 and RBOB Jan 16?
How do I make that chart?
Thanks and Regards,
Ank
[2015-12-11 17:34:40]
This can be done by using the Difference (Bar) study:
http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s3
Here are instructions to use a study:
Chart Studies: Adding/Modifying Chart Studies
[2015-12-22 09:42:46]
I read the links mentioned here but didn't get a solution for this.
Could you provide me with a simple formula for making a custom spread?
Lets say for eg. RBOB Feb 16 - Brent Crude Mar 16
It would be of great help.
[2015-12-22 21:31:26]
We are updating the documentation and we will post here when done.
[2015-12-24 03:37:17]
Here is the updated documentation which makes it very clear how to calculate the difference between 2 symbols:
http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#MultipleChartStudies (Multiple Chart Studies)
To be clear, you need to have 2 charts open. One for each symbol you want to calculate the difference between.
Date Time Of Last Edit: 2015-12-24 03:38:30
