Date/Time: Thu, 26 Dec 2024 12:47:05 +0000
Historical Data, Daily Chart
View Count: 679
[2015-12-11 08:54:53] |
User681584 - Posts: 4 |
Hi, If I open a daily historical chart for any exchange traded spread, it shows me a single candle. It does not provide me with the historical data for any of the products. Could you please help? Thanks |
[2015-12-11 11:16:20] |
Historical Daily data at this time is not supported for futures spreads with Easy Screen. We are in the process of setting this up and we expect it should be ready in about two weeks at the latest. However, the amount of historical data will be limited since we are only beginning to maintain this data at this time. There is a temporary solution and that is to use an Intraday chart and set the time period per bar to 1 Day. Here is the documentation for this: https://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#TimePeriodPerBar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-12-11 11:20:44
