Date/Time: Thu, 26 Dec 2024 07:32:17 +0000
Migrate SpredSheet autotrading to ACSIL ?
View Count: 703
[2015-12-10 19:06:58] |
User368248 - Posts: 46 |
Hello, I have working a spreadsheet with formulas, entries and exits. Are there some "automatic" way of migrate this SpreadSheet to acsil program/system/code? Thanks. |
[2015-12-10 19:53:38] |
There is no automatic way to do this. It has to be manually done. However, the automated trading logic works identically between Spreadsheets and ACSIL. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
