Date/Time: Thu, 26 Dec 2024 07:37:23 +0000
/ES Chart Bars not showing up
View Count: 797
[2015-12-10 12:55:41] |
MKL17 - Posts: 35 |
The bars dont seem to be showing up this morning, most likely do to contract change but I have not had this problem in the past and have the same settings. Any ideas? It is across all my /ES charts.
Date Time Of Last Edit: 2015-12-10 12:58:32
[2015-12-10 17:45:56] |
Go to the ES chart. Select Edit >> Delete All Data and Download. If there still is a problem, then provide the Message Log by following these instructions here: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Is the chart still updating in real-time? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
