Date/Time: Sun, 13 Sep 2026 01:58:58 +0000
SCT_ORDERTYPE_TRIGGERED_TRAILING_STOP_3_OFFSETS
View Count: 1543
| [2015-12-10 01:23:04] |
| User856618 - Posts: 12 |
Hi- Been a NinjaTrader user for sometime now and want migrate to Sierra Chart. Im want to use Advanced Custom Study Interface and Language using SCT_ORDERTYPE_TRIGGERED_TRAILING_STOP_3_OFFSETS 12.50% (Stop Offset), 5.00% (Trigger Offset), 1.00% (Trail Offset). I have a question specifically on how that order type would function using option contracts. Would the % offset be tied into the bid or ask? |
| [2015-12-10 03:47:23] |
I ask this because Im putting in market orders and need a barometer to measure these offfset %.
| [2015-12-10 07:33:48] |
Percentages for the order type SCT_ORDERTYPE_TRIGGERED_TRAILING_STOP_3_OFFSETS are not supported in ACSIL. You will be working with actual prices or price offsets relative to the parent order price. Not percentages.
| [2015-12-11 00:34:27] |
What SCT_ORDERTYPE_ would allow a profit take? I dont see it within the documentation here http://www.sierrachart.com/index.php?page=doc/doc_ACSILTrading.html#AttachedOrdersOCOMainOrderTypes
| [2015-12-11 11:09:40] |
Almost all of the order types support Attached Orders. What you are referring to is Attached Orders and this s_SCNewOrder member sets the offset for the Target Attached Order: https://www.sierrachart.com/index.php?page=doc/doc_ACSILTrading.html#TargetOffset Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
