Date/Time: Thu, 26 Dec 2024 07:18:44 +0000
DISCONNECTED - OUT OF THE BLUE
View Count: 1048
[2015-12-09 16:10:45]
AP - Posts: 117
It was ok until suddenly it was not and I was disconnected.
This has never happened before.
Will please appreciate if you can look into it -
see log for reference -
Software version: 1335 | 2015-12-09 10:44:01
Uses New Spreadsheets | 2015-12-09 10:44:01
Usage end date: 2015-12-24 | 2015-12-09 10:44:01
Enabled for: Advanced Features. | 2015-12-09 10:44:01
Enabled for: Advanced Features 2. | 2015-12-09 10:44:01
Enabled for: Sierra Chart Historical Data Service. | 2015-12-09 10:44:01
Allow Support for Sierra Chart Data Feeds is enabled. | 2015-12-09 10:44:01
Current selected Data/Trading service: CQG FIX Trading | 2015-12-09 10:44:01
Chart Update Interval: 500 | 2015-12-09 10:44:01
Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2015-12-09 10:44:01
2015-12-09 10:44:01 Local computer time | 2015-12-09 10:44:01
2015-12-09 15:44:01 Local computer time in UTC | 2015-12-09 10:44:01
2015-12-09 10:44:01 Local computer time in SC Time Zone | 2015-12-09 10:44:01
2015-12-09 15:43:55 Server time in UTC | 2015-12-09 10:44:01
Local computer UTC time and Server UTC time difference: 1 seconds. | 2015-12-09 10:44:01
Program path: C:\SierraChart\ | 2015-12-09 10:44:01
Data Files path: C:\SierraChart\Data\ | 2015-12-09 10:44:01
OS Version Number: 6.2 | 2015-12-09 10:44:01
Locale Information: C | 2015-12-09 10:44:01
Checking for new symbol settings for cqg | 2015-12-09 10:44:01
HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-12-09 10:44:01
HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2015-12-09 10:44:01
HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2015-12-09 10:44:01
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2015-12-09 10:44:02
Symbol settings are up-to-date for cqg | 2015-12-09 10:44:02
Files to Open on Start up | Opening file: MA-30, 60min.cht | 2015-12-09 10:44:04
Files to Open on Start up | Opening file: 30,15,5.cht | 2015-12-09 10:44:04
Files to Open on Start up | Opening file: PreToPost.cht | 2015-12-09 10:44:04
Files to Open on Start up | File does not exist: C:\SierraChart\Data\Charts-H,D,W.cht | 2015-12-09 10:44:05
Files to Open on Start up | Opening file: ES-H,D,W.cht | 2015-12-09 10:44:05
Files to Open on Start up | Opening file: SPX-H,D,W.cht | 2015-12-09 10:44:06
Files to Open on Start up | Opening file: SPX-Fibs.cht | 2015-12-09 10:44:06
Files to Open on Start up | File does not exist: C:\SierraChart\Data\Fibs2.cht | 2015-12-09 10:44:07
Files to Open on Start up | Opening file: Fibs.cht | 2015-12-09 10:44:07
Files to Open on Start up | Opening file: 5-MIN.cht | 2015-12-09 10:44:08
Files to Open on Start up | Opening file: 15-MIN.cht | 2015-12-09 10:44:08
Files to Open on Start up | Opening file: 30,15,5.cht | 2015-12-09 10:44:09
Files to Open on Start up | Opening file: Pattern-1H.cht | 2015-12-09 10:44:09
Files to Open on Start up | Opening file: Pattern-15MIN.cht | 2015-12-09 10:44:09
Files to Open on Start up | Opening file: Drawings.cht | 2015-12-09 10:44:10
Files to Open on Start up | Opening file: START.cht | 2015-12-09 10:44:11
Files to Open on Start up | Opening file: Levels.cht | 2015-12-09 10:44:14
Files to Open on Start up | Opening file: MAIN.cht | 2015-12-09 10:44:14
Files to Open on Start up | Opening file: Profile-MAIN, 15Min.cht | 2015-12-09 10:44:17
Files to Open on Start up | Opening file: Profile-Structure.cht | 2015-12-09 10:44:18
Files to Open on Start up | Opening file: Profile-Composite.cht | 2015-12-09 10:44:20
Files to Open on Start up | Opening file: Profile-VPOCs.cht | 2015-12-09 10:44:21
Files to Open on Start up | Opening file: AssetClass-Futures.cht | 2015-12-09 10:44:22
Unable to determine transition date based on volume from files: CLF16.dly, CLG16.dly | 2015-12-09 10:44:22
The CLG16.dly symbol may not be the active contract month. | 2015-12-09 10:44:22
Files to Open on Start up | Opening file: AUTOTRENDLINES.cht | 2015-12-09 10:44:25
Files to Open on Start up | Opening file: MA-Dly.cht | 2015-12-09 10:44:29
Chart #7 has tagged chart #4 for full recalculation. Chartbook: PreToPost.cht | 2015-12-09 10:44:31
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2015-12-09 10:44:31
HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2015-12-09 10:44:31
HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2015-12-09 10:44:31
Chart #7 has tagged chart #6 for full recalculation. Chartbook: START.cht | 2015-12-09 10:44:32
Chart #16 has tagged chart #14 for full recalculation. Chartbook: START.cht | 2015-12-09 10:44:32
Chart #15 has tagged chart #14 for full recalculation. Chartbook: START.cht | 2015-12-09 10:44:32
Chart #20 has tagged chart #15 for full recalculation. Chartbook: START.cht | 2015-12-09 10:44:32
Chart #17 has tagged chart #14 for full recalculation. Chartbook: START.cht | 2015-12-09 10:44:32
Chart #19 has tagged chart #16 for full recalculation. Chartbook: START.cht | 2015-12-09 10:44:32
Chart #21 has tagged chart #14 for full recalculation. Chartbook: START.cht | 2015-12-09 10:44:32
Chart #32 has tagged chart #14 for full recalculation. Chartbook: START.cht | 2015-12-09 10:44:32
Chart #33 has tagged chart #32 for full recalculation. Chartbook: START.cht | 2015-12-09 10:44:32
Chart #31 has tagged chart #14 for full recalculation. Chartbook: START.cht | 2015-12-09 10:44:32
Chart #35 has tagged chart #14 for full recalculation. Chartbook: START.cht | 2015-12-09 10:44:32
Chart #10 has tagged chart #9 for full recalculation. Chartbook: MAIN.cht | 2015-12-09 10:44:37
Intraday data recording state for symbol F.US.EPZ15 is set to download 'Pending'. | 2015-12-09 10:44:39
HD Request # 2 | Downloading Intraday chart data for F.US.EPZ15 to the file F.US.EPZ15.scid. Service: cqg | 2015-12-09 10:44:39
HD Request # 2 | Download start Date-Time: 2015-12-09 10:32:54.000 | 2015-12-09 10:44:39
HD Request # 2 | Using server: ds3.sierracharts.com port 10149 | 2015-12-09 10:44:39
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-12-09 10:44:39
Socket (4) | Connected. | 2015-12-09 10:44:40
HD Request # 2 | Sending historical data logon request message. | 2015-12-09 10:44:40
Intraday data recording state for symbol F.US.TFEZ15 is set to download 'Pending'. | 2015-12-09 10:44:40
HD Request # 2 | Requesting Intraday data. Start Date-Time: 2015-12-09 10:32:54. Record interval: 0. Symbol: F.US.EPZ15 | 2015-12-09 10:44:40
Intraday data recording state for symbol ADR-NYSE is set to download 'Pending'. | 2015-12-09 10:44:40
Socket (4) | Shutdown and closed. | 2015-12-09 10:44:40
The network socket for historical data has been closed. | 2015-12-09 10:44:40
Intraday data recording state for symbol ADV-NYSE is set to download 'Pending'. | 2015-12-09 10:44:40
ADV-NYSE [M] 5 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: PreToPost.cht | 2015-12-09 10:44:40
HD Request # 2 | Historical data for F.US.EPZ15 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-12-09 10:44:40
HD Request # 2 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.EPZ15 | 2015-12-09 10:44:40
HD Request # 2 | Intraday download COMPLETE for F.US.EPZ15. Completion time: 0s. Unique request ID: 1 | 2015-12-09 10:44:40
Removed historical data download ID 1 | 2015-12-09 10:44:40
HD Request # 3 | Downloading Intraday chart data for F.US.TFEZ15 to the file F.US.TFEZ15.scid. Service: cqg | 2015-12-09 10:44:40
HD Request # 3 | Download start Date-Time: 2015-12-09 10:32:52.000 | 2015-12-09 10:44:40
HD Request # 3 | Using server: ds5.sierracharts.com port 10149 | 2015-12-09 10:44:40
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-12-09 10:44:40
Intraday data recording state for symbol DECL-NYSE is set to download 'Pending'. | 2015-12-09 10:44:40
Intraday data recording state for symbol F.US.ENQZ15 is set to download 'Pending'. | 2015-12-09 10:44:40
Socket (5) | Connected. | 2015-12-09 10:44:40
HD Request # 3 | Sending historical data logon request message. | 2015-12-09 10:44:40
Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. | 2015-12-09 10:44:40
HD Request # 4 | Downloading Historical Daily chart data for F.US.EPZ15. Starting date: 2015-12-08. Service: cqg | 2015-12-09 10:44:40
HD Request # 4 | Requesting historical Daily data for ESZ15 starting at 2015-12-07 | 2015-12-09 10:44:40
HTTP connection to ds01.ddfplus.com:80 (0) | Resolved address ds01.ddfplus.com to IP 8.18.161.123 | 2015-12-09 10:44:40
HTTP connection to ds01.ddfplus.com:80 (6) | Connected. | 2015-12-09 10:44:40
HD Request # 4 | Receiving historical Daily data for F.US.EPZ15 starting at 2015-12-07 | 2015-12-09 10:44:40
Writing historical Daily data for F.US.EPZ15 to the file F.US.EPZ15.dly | 2015-12-09 10:44:40
HD Request # 4 | Received 3 records from 2015-12-07 00:00:00 to 2015-12-09 00:00:00 (3.0 days) and wrote 2 records for F.US.EPZ15 | 2015-12-09 10:44:40
HD Request # 4 | Daily download COMPLETE for F.US.EPZ15. Completion time: 0s. Unique request ID: 8 | 2015-12-09 10:44:40
Removed historical data download ID 8 | 2015-12-09 10:44:40
HD Request # 5 | Downloading Historical Daily chart data for $SPX. Starting date: 2015-12-07. Service: cboe.index | 2015-12-09 10:44:40
HD Request # 5 | Requesting historical Daily data for $SPX starting at 2015-12-06 | 2015-12-09 10:44:40
HD Request # 3 | Requesting Intraday data. Start Date-Time: 2015-12-09 10:32:52. Record interval: 0. Symbol: F.US.TFEZ15 | 2015-12-09 10:44:41
Socket (5) | Shutdown and closed. | 2015-12-09 10:44:41
The network socket for historical data has been closed. | 2015-12-09 10:44:41
HD Request # 5 | Receiving historical Daily data for $SPX starting at 2015-12-07 | 2015-12-09 10:44:41
Writing historical Daily data for $SPX to the file $SPX.dly | 2015-12-09 10:44:41
HD Request # 5 | Received 3 records from 2015-12-07 00:00:00 to 2015-12-09 00:00:00 (3.0 days) and wrote 3 records for $SPX | 2015-12-09 10:44:41
HD Request # 5 | Daily download COMPLETE for $SPX. Completion time: 1s. Unique request ID: 9 | 2015-12-09 10:44:41
Removed historical data download ID 9 | 2015-12-09 10:44:41
HD Request # 3 | Historical data for F.US.TFEZ15 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-12-09 10:44:41
HD Request # 3 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.TFEZ15 | 2015-12-09 10:44:41
HD Request # 3 | Intraday download COMPLETE for F.US.TFEZ15. Completion time: 1s. Unique request ID: 2 | 2015-12-09 10:44:41
Removed historical data download ID 2 | 2015-12-09 10:44:41
HD Request # 6 | Downloading Intraday chart data for ADR-NYSE to the file ADR-NYSE.scid. Service: statscalc | 2015-12-09 10:44:41
HD Request # 6 | Download start Date-Time: 2015-12-09 10:35:57.000 | 2015-12-09 10:44:41
HD Request # 6 | Using server: ds4.sierracharts.com port 10149 | 2015-12-09 10:44:41
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-12-09 10:44:41
Intraday data recording state for symbol F.US.YMZ15 is set to download 'Pending'. | 2015-12-09 10:44:41
Socket (7) | Connected. | 2015-12-09 10:44:41
HD Request # 6 | Sending historical data logon request message. | 2015-12-09 10:44:41
HD Request # 6 | Requesting Intraday data. Start Date-Time: 2015-12-09 10:35:57. Record interval: 0. Symbol: ADR-NYSE | 2015-12-09 10:44:41
HD Request # 6 | Decompressing data. | 2015-12-09 10:44:41
HD Request # 6 | Receiving Intraday data for ADR-NYSE starting at 2015-12-09 10:35:57 | 2015-12-09 10:44:41
HD Request # 6 | Timestamp of first Intraday data file record written: 2015-12-09 10:35:58 | 2015-12-09 10:44:41
Socket (7) | Shutdown and closed. | 2015-12-09 10:44:41
HD Request # 6 | Historical data for ADR-NYSE is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-12-09 10:44:41
HD Request # 6 | Received 522 records from 2015-12-09 10:35:57 to 2015-12-09 10:44:38 (8.7 minutes) and wrote 521 records for ADR-NYSE | 2015-12-09 10:44:41
HD Request # 6 | Intraday download COMPLETE for ADR-NYSE. Completion time: 0s. Unique request ID: 3 | 2015-12-09 10:44:41
Removed historical data download ID 3 | 2015-12-09 10:44:41
HD Request # 7 | Downloading Intraday chart data for ADV-NYSE to the file ADV-NYSE.scid. Service: statscalc | 2015-12-09 10:44:41
HD Request # 7 | Download start Date-Time: 2015-12-09 10:35:57.000 | 2015-12-09 10:44:41
HD Request # 7 | Using server: ds3.sierracharts.com port 10149 | 2015-12-09 10:44:41
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-12-09 10:44:41
ADV-NYSE [M] 5 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: START.cht | 2015-12-09 10:44:41
Socket (8) | Connected. | 2015-12-09 10:44:41
HD Request # 7 | Sending historical data logon request message. | 2015-12-09 10:44:41
HD Request # 7 | Requesting Intraday data. Start Date-Time: 2015-12-09 10:35:57. Record interval: 0. Symbol: ADV-NYSE | 2015-12-09 10:44:41
HD Request # 7 | Decompressing data. | 2015-12-09 10:44:41
HD Request # 7 | Receiving Intraday data for ADV-NYSE starting at 2015-12-09 10:35:57 | 2015-12-09 10:44:41
HD Request # 7 | Timestamp of first Intraday data file record written: 2015-12-09 10:35:58 | 2015-12-09 10:44:41
Socket (8) | Shutdown and closed. | 2015-12-09 10:44:41
HD Request # 7 | Historical data for ADV-NYSE is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-12-09 10:44:41
HD Request # 7 | Received 522 records from 2015-12-09 10:35:57 to 2015-12-09 10:44:38 (8.7 minutes) and wrote 521 records for ADV-NYSE | 2015-12-09 10:44:41
HD Request # 7 | Intraday download COMPLETE for ADV-NYSE. Completion time: 0s. Unique request ID: 4 | 2015-12-09 10:44:41
Removed historical data download ID 4 | 2015-12-09 10:44:41
HD Request # 8 | Downloading Intraday chart data for DECL-NYSE to the file DECL-NYSE.scid. Service: statscalc | 2015-12-09 10:44:41
HD Request # 8 | Download start Date-Time: 2015-12-09 10:35:57.000 | 2015-12-09 10:44:41
HD Request # 8 | Using server: ds5.sierracharts.com port 10149 | 2015-12-09 10:44:41
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-12-09 10:44:41
Intraday data recording state for symbol UVOL-NYSE is set to download 'Pending'. | 2015-12-09 10:44:41
UVOL-NYSE [M] 15 Min #14 | Performing a full recalculation because it has been tagged. Chartbook: START.cht | 2015-12-09 10:44:41
Intraday data recording state for symbol UVOL-NASDAQ is set to download 'Pending'. | 2015-12-09 10:44:41
UVOL-NASDAQ [M] 15 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: START.cht | 2015-12-09 10:44:41
Chart #15 has tagged chart #14 for full recalculation. Chartbook: START.cht | 2015-12-09 10:44:41
Intraday data recording state for symbol UVOL-TF is set to download 'Pending'. | 2015-12-09 10:44:41
UVOL-TF [M] 15 Min #16 | Performing a full recalculation because it has been tagged. Chartbook: START.cht | 2015-12-09 10:44:41
Chart #16 has tagged chart #14 for full recalculation. Chartbook: START.cht | 2015-12-09 10:44:41
Intraday data recording state for symbol UVOL-YM is set to download 'Pending'. | 2015-12-09 10:44:41
Intraday data recording state for symbol DVOL-YM is set to download 'Pending'. | 2015-12-09 10:44:41
Intraday data recording state for symbol DVOL-TF is set to download 'Pending'. | 2015-12-09 10:44:41
Intraday data recording state for symbol DVOL-NASDAQ is set to download 'Pending'. | 2015-12-09 10:44:41
Intraday data recording state for symbol DVOL-NYSE is set to download 'Pending'. | 2015-12-09 10:44:41
Socket (9) | Connected. | 2015-12-09 10:44:41
HD Request # 8 | Sending historical data logon request message. | 2015-12-09 10:44:41
Intraday data recording state for symbol ADR-TF is set to download 'Pending'. | 2015-12-09 10:44:41
Intraday data recording state for symbol ADR-NASDAQ is set to download 'Pending'. | 2015-12-09 10:44:41
HD Request # 8 | Requesting Intraday data. Start Date-Time: 2015-12-09 10:35:57. Record interval: 0. Symbol: DECL-NYSE | 2015-12-09 10:44:41
HD Request # 8 | Decompressing data. | 2015-12-09 10:44:42
HD Request # 8 | Receiving Intraday data for DECL-NYSE starting at 2015-12-09 10:35:57 | 2015-12-09 10:44:42
HD Request # 8 | Timestamp of first Intraday data file record written: 2015-12-09 10:35:58 | 2015-12-09 10:44:42
Socket (9) | Shutdown and closed. | 2015-12-09 10:44:42
The network socket for historical data has been closed. | 2015-12-09 10:44:42
HD Request # 8 | Historical data for DECL-NYSE is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-12-09 10:44:42
HD Request # 8 | Received 524 records from 2015-12-09 10:35:57 to 2015-12-09 10:44:40 (8.7 minutes) and wrote 523 records for DECL-NYSE | 2015-12-09 10:44:42
HD Request # 8 | Intraday download COMPLETE for DECL-NYSE. Completion time: 1s. Unique request ID: 5 | 2015-12-09 10:44:42
Removed historical data download ID 5 | 2015-12-09 10:44:42
HD Request # 9 | Downloading Intraday chart data for F.US.ENQZ15 to the file F.US.ENQZ15.scid. Service: cqg | 2015-12-09 10:44:42
HD Request # 9 | Download start Date-Time: 2015-12-09 10:32:54.000 | 2015-12-09 10:44:42
HD Request # 9 | Using server: ds4.sierracharts.com port 10149 | 2015-12-09 10:44:42
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-12-09 10:44:42
Socket (10) | Connected. | 2015-12-09 10:44:42
HD Request # 9 | Sending historical data logon request message. | 2015-12-09 10:44:42
Intraday data recording state for symbol ADR-YM is set to download 'Pending'. | 2015-12-09 10:44:42
HD Request # 9 | Requesting Intraday data. Start Date-Time: 2015-12-09 10:32:54. Record interval: 0. Symbol: F.US.ENQZ15 | 2015-12-09 10:44:42
DVOL-NYSE [M] 15 Min #32 | Performing a full recalculation because it has been tagged. Chartbook: START.cht | 2015-12-09 10:44:42
Chart #32 has tagged chart #14 for full recalculation. Chartbook: START.cht | 2015-12-09 10:44:42
Socket (10) | Shutdown and closed. | 2015-12-09 10:44:42
HD Request # 9 | Historical data for F.US.ENQZ15 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-12-09 10:44:42
HD Request # 9 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.ENQZ15 | 2015-12-09 10:44:42
HD Request # 9 | Intraday download COMPLETE for F.US.ENQZ15. Completion time: 0s. Unique request ID: 6 | 2015-12-09 10:44:42
Removed historical data download ID 6 | 2015-12-09 10:44:42
HD Request # 10 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2015-12-09 10:44:42
HD Request # 10 | Download start Date-Time: 2015-12-09 10:35:57.000 | 2015-12-09 10:44:42
HD Request # 10 | Using server: ds3.sierracharts.com port 10149 | 2015-12-09 10:44:42
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-12-09 10:44:42
Intraday data recording state for symbol F.US.CLEF16 is set to download 'Pending'. | 2015-12-09 10:44:42
Socket (11) | Connected. | 2015-12-09 10:44:42
HD Request # 10 | Sending historical data logon request message. | 2015-12-09 10:44:42
HD Request # 10 | Requesting Intraday data. Start Date-Time: 2015-12-09 10:35:57. Record interval: 0. Symbol: TICK-NYSE | 2015-12-09 10:44:42
HD Request # 10 | Decompressing data. | 2015-12-09 10:44:42
HD Request # 10 | Receiving Intraday data for TICK-NYSE starting at 2015-12-09 10:35:57 | 2015-12-09 10:44:42
HD Request # 10 | Timestamp of first Intraday data file record written: 2015-12-09 10:35:58 | 2015-12-09 10:44:42
Socket (11) | Shutdown and closed. | 2015-12-09 10:44:42
HD Request # 10 | Historical data for TICK-NYSE is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-12-09 10:44:42
HD Request # 10 | Received 525 records from 2015-12-09 10:35:57 to 2015-12-09 10:44:41 (8.7 minutes) and wrote 524 records for TICK-NYSE | 2015-12-09 10:44:42
HD Request # 10 | Intraday download COMPLETE for TICK-NYSE. Completion time: 0s. Unique request ID: 7 | 2015-12-09 10:44:42
Removed historical data download ID 7 | 2015-12-09 10:44:42
HD Request # 11 | Downloading Intraday chart data for F.US.YMZ15 to the file F.US.YMZ15.scid. Service: cqg | 2015-12-09 10:44:42
HD Request # 11 | Download start Date-Time: 2015-12-09 10:32:54.000 | 2015-12-09 10:44:42
HD Request # 11 | Using server: ds5.sierracharts.com port 10149 | 2015-12-09 10:44:42
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-12-09 10:44:42
Chart #10 has tagged chart #9 for full recalculation. Chartbook: MAIN.cht | 2015-12-09 10:44:42
ADV-NYSE [M] 5 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: MAIN.cht | 2015-12-09 10:44:42
Socket (12) | Connected. | 2015-12-09 10:44:42
HD Request # 11 | Sending historical data logon request message. | 2015-12-09 10:44:42
HD Request # 11 | Requesting Intraday data. Start Date-Time: 2015-12-09 10:32:54. Record interval: 0. Symbol: F.US.YMZ15 | 2015-12-09 10:44:42
Socket (12) | Shutdown and closed. | 2015-12-09 10:44:42
HD Request # 11 | Historical data for F.US.YMZ15 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-12-09 10:44:42
HD Request # 11 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.YMZ15 | 2015-12-09 10:44:42
HD Request # 11 | Intraday download COMPLETE for F.US.YMZ15. Completion time: 0s. Unique request ID: 10 | 2015-12-09 10:44:42
Removed historical data download ID 10 | 2015-12-09 10:44:42
HD Request # 12 | Downloading Intraday chart data for UVOL-NYSE to the file UVOL-NYSE.scid. Service: statscalc | 2015-12-09 10:44:42
HD Request # 12 | Download start Date-Time: 2015-12-09 10:35:57.000 | 2015-12-09 10:44:42
HD Request # 12 | Using server: ds4.sierracharts.com port 10149 | 2015-12-09 10:44:42
Socket (13) | Connected. | 2015-12-09 10:44:42
HD Request # 12 | Sending historical data logon request message. | 2015-12-09 10:44:42
HD Request # 12 | Requesting Intraday data. Start Date-Time: 2015-12-09 10:35:57. Record interval: 0. Symbol: UVOL-NYSE | 2015-12-09 10:44:42
HD Request # 12 | Decompressing data. | 2015-12-09 10:44:42
HD Request # 12 | Receiving Intraday data for UVOL-NYSE starting at 2015-12-09 10:35:57 | 2015-12-09 10:44:42
HD Request # 12 | Timestamp of first Intraday data file record written: 2015-12-09 10:35:58 | 2015-12-09 10:44:42
Socket (13) | Shutdown and closed. | 2015-12-09 10:44:42
HD Request # 12 | Historical data for UVOL-NYSE is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-12-09 10:44:42
HD Request # 12 | Received 524 records from 2015-12-09 10:35:57 to 2015-12-09 10:44:40 (8.7 minutes) and wrote 523 records for UVOL-NYSE | 2015-12-09 10:44:42
HD Request # 12 | Intraday download COMPLETE for UVOL-NYSE. Completion time: 0s. Unique request ID: 11 | 2015-12-09 10:44:42
Removed historical data download ID 11 | 2015-12-09 10:44:42
HD Request # 13 | Downloading Intraday chart data for UVOL-NASDAQ to the file UVOL-NASDAQ.scid. Service: statscalc | 2015-12-09 10:44:42
HD Request # 13 | Download start Date-Time: 2015-12-09 10:35:57.000 | 2015-12-09 10:44:42
HD Request # 13 | Using server: ds3.sierracharts.com port 10149 | 2015-12-09 10:44:42
Socket (14) | Connected. | 2015-12-09 10:44:42
HD Request # 13 | Sending historical data logon request message. | 2015-12-09 10:44:42
Intraday data recording state for symbol F.US.USAH16 is set to download 'Pending'. | 2015-12-09 10:44:42
Intraday data recording state for symbol F.US.GCEG16 is set to download 'Pending'. | 2015-12-09 10:44:42
HD Request # 13 | Requesting Intraday data. Start Date-Time: 2015-12-09 10:35:57. Record interval: 0. Symbol: UVOL-NASDAQ | 2015-12-09 10:44:42
HD Request # 13 | Decompressing data. | 2015-12-09 10:44:42
HD Request # 13 | Receiving Intraday data for UVOL-NASDAQ starting at 2015-12-09 10:35:57 | 2015-12-09 10:44:42
HD Request # 13 | Timestamp of first Intraday data file record written: 2015-12-09 10:35:58 | 2015-12-09 10:44:42
Socket (14) | Shutdown and closed. | 2015-12-09 10:44:42
HD Request # 13 | Historical data for UVOL-NASDAQ is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-12-09 10:44:42
HD Request # 13 | Received 525 records from 2015-12-09 10:35:57 to 2015-12-09 10:44:41 (8.7 minutes) and wrote 524 records for UVOL-NASDAQ | 2015-12-09 10:44:42
HD Request # 13 | Intraday download COMPLETE for UVOL-NASDAQ. Completion time: 0s. Unique request ID: 12 | 2015-12-09 10:44:42
Removed historical data download ID 12 | 2015-12-09 10:44:42
HD Request # 14 | Downloading Intraday chart data for UVOL-TF to the file UVOL-TF.scid. Service: statscalc | 2015-12-09 10:44:42
HD Request # 14 | Download start Date-Time: 2015-12-09 10:35:57.000 | 2015-12-09 10:44:42
HD Request # 14 | Using server: ds5.sierracharts.com port 10149 | 2015-12-09 10:44:42
Intraday data recording state for symbol F.US.CLEG16 is set to download 'Pending'. | 2015-12-09 10:44:43
Intraday data recording state for symbol F.US.TYAH16 is set to download 'Pending'. | 2015-12-09 10:44:43
Socket (15) | Connected. | 2015-12-09 10:44:43
HD Request # 14 | Sending historical data logon request message. | 2015-12-09 10:44:43
Intraday data recording state for symbol F.US.DXEZ15 is set to download 'Pending'. | 2015-12-09 10:44:43
F.US.EPZ15 [CBV] Daily #1 | Reloading chart. | 2015-12-09 10:44:43
HD Request # 14 | Requesting Intraday data. Start Date-Time: 2015-12-09 10:35:57. Record interval: 0. Symbol: UVOL-TF | 2015-12-09 10:44:43
HD Request # 14 | Decompressing data. | 2015-12-09 10:44:43
HD Request # 14 | Receiving Intraday data for UVOL-TF starting at 2015-12-09 10:35:57 | 2015-12-09 10:44:43
HD Request # 14 | Timestamp of first Intraday data file record written: 2015-12-09 10:35:58 | 2015-12-09 10:44:43
Socket (15) | Shutdown and closed. | 2015-12-09 10:44:43
The network socket for historical data has been closed. | 2015-12-09 10:44:43
HD Request # 14 | Historical data for UVOL-TF is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-12-09 10:44:43
HD Request # 14 | Received 525 records from 2015-12-09 10:35:57 to 2015-12-09 10:44:41 (8.7 minutes) and wrote 524 records for UVOL-TF | 2015-12-09 10:44:43
HD Request # 14 | Intraday download COMPLETE for UVOL-TF. Completion time: 0s. Unique request ID: 13 | 2015-12-09 10:44:43
Removed historical data download ID 13 | 2015-12-09 10:44:43
HD Request # 15 | Downloading Intraday chart data for UVOL-YM to the file UVOL-YM.scid. Service: statscalc | 2015-12-09 10:44:43
HD Request # 15 | Download start Date-Time: 2015-12-09 10:35:57.000 | 2015-12-09 10:44:43
HD Request # 15 | Using server: ds4.sierracharts.com port 10149 | 2015-12-09 10:44:43
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-12-09 10:44:43
F.US.EPZ15 Weekly #2 | Reloading chart. | 2015-12-09 10:44:43
Socket (16) | Connected. | 2015-12-09 10:44:43
HD Request # 15 | Sending historical data logon request message. | 2015-12-09 10:44:43
$SPX Monthly #5 | Reloading chart. | 2015-12-09 10:44:43
HD Request # 15 | Requesting Intraday data. Start Date-Time: 2015-12-09 10:35:57. Record interval: 0. Symbol: UVOL-YM | 2015-12-09 10:44:43
HD Request # 15 | Decompressing data. | 2015-12-09 10:44:44
HD Request # 15 | Receiving Intraday data for UVOL-YM starting at 2015-12-09 10:35:57 | 2015-12-09 10:44:44
HD Request # 15 | Timestamp of first Intraday data file record written: 2015-12-09 10:35:58 | 2015-12-09 10:44:44
Socket (16) | Shutdown and closed. | 2015-12-09 10:44:44
The network socket for historical data has been closed. | 2015-12-09 10:44:44
HD Request # 15 | Historical data for UVOL-YM is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-12-09 10:44:44
HD Request # 15 | Received 526 records from 2015-12-09 10:35:57 to 2015-12-09 10:44:42 (8.8 minutes) and wrote 525 records for UVOL-YM | 2015-12-09 10:44:44
HD Request # 15 | Intraday download COMPLETE for UVOL-YM. Completion time: 1s. Unique request ID: 14 | 2015-12-09 10:44:44
Removed historical data download ID 14 | 2015-12-09 10:44:44
HD Request # 16 | Downloading Intraday chart data for DVOL-YM to the file DVOL-YM.scid. Service: statscalc | 2015-12-09 10:44:44
HD Request # 16 | Download start Date-Time: 2015-12-09 10:35:57.000 | 2015-12-09 10:44:44
HD Request # 16 | Using server: ds3.sierracharts.com port 10149 | 2015-12-09 10:44:44
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-12-09 10:44:44
F.US.EPZ15 Daily #1 | Reloading chart. | 2015-12-09 10:44:44
HD Request # 17 | Downloading Historical Daily chart data for F.US.ENQZ15. Starting date: 2015-12-08. Service: cqg | 2015-12-09 10:44:44
HD Request # 17 | Requesting historical Daily data for NQZ15 starting at 2015-12-07 | 2015-12-09 10:44:44
Socket (17) | Connected. | 2015-12-09 10:44:44
HD Request # 16 | Sending historical data logon request message. | 2015-12-09 10:44:44
HD Request # 16 | Requesting Intraday data. Start Date-Time: 2015-12-09 10:35:57. Record interval: 0. Symbol: DVOL-YM | 2015-12-09 10:44:44
HD Request # 16 | Decompressing data. | 2015-12-09 10:44:44
HD Request # 16 | Receiving Intraday data for DVOL-YM starting at 2015-12-09 10:35:57 | 2015-12-09 10:44:44
HD Request # 16 | Timestamp of first Intraday data file record written: 2015-12-09 10:35:58 | 2015-12-09 10:44:44
Socket (17) | Shutdown and closed. | 2015-12-09 10:44:44
HD Request # 17 | Receiving historical Daily data for F.US.ENQZ15 starting at 2015-12-07 | 2015-12-09 10:44:44
Writing historical Daily data for F.US.ENQZ15 to the file F.US.ENQZ15.dly | 2015-12-09 10:44:44
HD Request # 17 | Received 3 records from 2015-12-07 00:00:00 to 2015-12-09 00:00:00 (3.0 days) and wrote 2 records for F.US.ENQZ15 | 2015-12-09 10:44:44
HD Request # 17 | Daily download COMPLETE for F.US.ENQZ15. Completion time: 0s. Unique request ID: 28 | 2015-12-09 10:44:44
Removed historical data download ID 28 | 2015-12-09 10:44:44
HD Request # 18 | Downloading Historical Daily chart data for $NASX. Starting date: 2015-12-07. Service: nasdaq.index | 2015-12-09 10:44:44
HD Request # 18 | Requesting historical Daily data for $NASX starting at 2015-12-06 | 2015-12-09 10:44:44
HD Request # 16 | Historical data for DVOL-YM is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-12-09 10:44:44
HD Request # 16 | Received 526 records from 2015-12-09 10:35:57 to 2015-12-09 10:44:42 (8.8 minutes) and wrote 525 records for DVOL-YM | 2015-12-09 10:44:44
HD Request # 16 | Intraday download COMPLETE for DVOL-YM. Completion time: 0s. Unique request ID: 15 | 2015-12-09 10:44:44
Removed historical data download ID 15 | 2015-12-09 10:44:44
HD Request # 19 | Downloading Intraday chart data for DVOL-TF to the file DVOL-TF.scid. Service: statscalc | 2015-12-09 10:44:44
HD Request # 19 | Download start Date-Time: 2015-12-09 10:35:57.000 | 2015-12-09 10:44:44
HD Request # 19 | Using server: ds5.sierracharts.com port 10149 | 2015-12-09 10:44:44
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-12-09 10:44:44
$SPX Daily #4 | Reloading chart. | 2015-12-09 10:44:44
Socket (18) | Connected. | 2015-12-09 10:44:44
HD Request # 19 | Sending historical data logon request message. | 2015-12-09 10:44:44
HD Request # 19 | Requesting Intraday data. Start Date-Time: 2015-12-09 10:35:57. Record interval: 0. Symbol: DVOL-TF | 2015-12-09 10:44:44
HD Request # 19 | Decompressing data. | 2015-12-09 10:44:44
HD Request # 19 | Receiving Intraday data for DVOL-TF starting at 2015-12-09 10:35:57 | 2015-12-09 10:44:44
HD Request # 19 | Timestamp of first Intraday data file record written: 2015-12-09 10:35:58 | 2015-12-09 10:44:44
HD Request # 18 | Receiving historical Daily data for $NASX starting at 2015-12-07 | 2015-12-09 10:44:44
Socket (18) | Shutdown and closed. | 2015-12-09 10:44:44
Writing historical Daily data for $NASX to the file $NASX.dly | 2015-12-09 10:44:44
HD Request # 18 | Received 3 records from 2015-12-07 00:00:00 to 2015-12-09 00:00:00 (3.0 days) and wrote 3 records for $NASX | 2015-12-09 10:44:44
HD Request # 18 | Daily download COMPLETE for $NASX. Completion time: 1s. Unique request ID: 29 | 2015-12-09 10:44:45
Removed historical data download ID 29 | 2015-12-09 10:44:45
HD Request # 19 | Historical data for DVOL-TF is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-12-09 10:44:45
HD Request # 19 | Received 525 records from 2015-12-09 10:35:57 to 2015-12-09 10:44:41 (8.7 minutes) and wrote 524 records for DVOL-TF | 2015-12-09 10:44:45
HD Request # 19 | Intraday download COMPLETE for DVOL-TF. Completion time: 1s. Unique request ID: 16 | 2015-12-09 10:44:45
Removed historical data download ID 16 | 2015-12-09 10:44:45
HD Request # 20 | Downloading Historical Daily chart data for F.US.TFEZ15. Starting date: 2015-12-08. Service: cqg | 2015-12-09 10:44:45
HD Request # 20 | Requesting historical Daily data for RJZ15 starting at 2015-12-07 | 2015-12-09 10:44:45
HD Request # 21 | Downloading Intraday chart data for DVOL-NASDAQ to the file DVOL-NASDAQ.scid. Service: statscalc | 2015-12-09 10:44:45
HD Request # 21 | Download start Date-Time: 2015-12-09 10:35:57.000 | 2015-12-09 10:44:45
HD Request # 21 | Using server: ds4.sierracharts.com port 10149 | 2015-12-09 10:44:45
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-12-09 10:44:45
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2015-12-09 10:44:45
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2015-12-09 10:44:45
Socket (19) | Connected. | 2015-12-09 10:44:45
HD Request # 21 | Sending historical data logon request message. | 2015-12-09 10:44:45
HD Request # 21 | Requesting Intraday data. Start Date-Time: 2015-12-09 10:35:57. Record interval: 0. Symbol: DVOL-NASDAQ | 2015-12-09 10:44:45
socket (20) | Connected. | 2015-12-09 10:44:45
HD Request # 20 | Receiving historical Daily data for F.US.TFEZ15 starting at 2015-12-07 | 2015-12-09 10:44:45
Writing historical Daily data for F.US.TFEZ15 to the file F.US.TFEZ15.dly | 2015-12-09 10:44:45
HD Request # 20 | Received 3 records from 2015-12-07 00:00:00 to 2015-12-09 00:00:00 (3.0 days) and wrote 2 records for F.US.TFEZ15 | 2015-12-09 10:44:45
HD Request # 20 | Daily download COMPLETE for F.US.TFEZ15. Completion time: 0s. Unique request ID: 30 | 2015-12-09 10:44:45
Removed historical data download ID 30 | 2015-12-09 10:44:45
HD Request # 22 | Downloading Historical Daily chart data for $RSC. Starting date: 2015-12-07. Service: russell.index | 2015-12-09 10:44:45
HD Request # 22 | Requesting historical Daily data for $RSC starting at 2015-12-06 | 2015-12-09 10:44:45
HD Request # 21 | Decompressing data. | 2015-12-09 10:44:45
HD Request # 21 | Receiving Intraday data for DVOL-NASDAQ starting at 2015-12-09 10:35:57 | 2015-12-09 10:44:45
HD Request # 21 | Timestamp of first Intraday data file record written: 2015-12-09 10:35:58 | 2015-12-09 10:44:45
Socket (19) | Shutdown and closed. | 2015-12-09 10:44:45
The network socket for historical data has been closed. | 2015-12-09 10:44:45
HD Request # 22 | Receiving historical Daily data for $RSC starting at 2015-12-07 | 2015-12-09 10:44:45
Writing historical Daily data for $RSC to the file $RSC.dly | 2015-12-09 10:44:45
HD Request # 22 | Received 3 records from 2015-12-07 00:00:00 to 2015-12-09 00:00:00 (3.0 days) and wrote 3 records for $RSC | 2015-12-09 10:44:45
HD Request # 22 | Daily download COMPLETE for $RSC. Completion time: 0s. Unique request ID: 31 | 2015-12-09 10:44:45
Removed historical data download ID 31 | 2015-12-09 10:44:45
HD Request # 21 | Historical data for DVOL-NASDAQ is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-12-09 10:44:45
HD Request # 21 | Received 526 records from 2015-12-09 10:35:57 to 2015-12-09 10:44:42 (8.8 minutes) and wrote 525 records for DVOL-NASDAQ | 2015-12-09 10:44:45
HD Request # 21 | Intraday download COMPLETE for DVOL-NASDAQ. Completion time: 0s. Unique request ID: 17 | 2015-12-09 10:44:45
Removed historical data download ID 17 | 2015-12-09 10:44:45
HD Request # 23 | Downloading Historical Daily chart data for F.US.YMZ15. Starting date: 2015-12-08. Service: cqg | 2015-12-09 10:44:45
HD Request # 23 | Requesting historical Daily data for YMZ15 starting at 2015-12-07 | 2015-12-09 10:44:45
HD Request # 24 | Downloading Intraday chart data for DVOL-NYSE to the file DVOL-NYSE.scid. Service: statscalc | 2015-12-09 10:44:45
HD Request # 24 | Download start Date-Time: 2015-12-09 10:35:57.000 | 2015-12-09 10:44:45
HD Request # 24 | Using server: ds3.sierracharts.com port 10149 | 2015-12-09 10:44:45
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-12-09 10:44:45
Socket (21) | Connected. | 2015-12-09 10:44:45
HD Request # 24 | Sending historical data logon request message. | 2015-12-09 10:44:45
HD Request # 24 | Requesting Intraday data. Start Date-Time: 2015-12-09 10:35:57. Record interval: 0. Symbol: DVOL-NYSE | 2015-12-09 10:44:45
F.US.EPZ15 Daily #2 | Reloading chart. | 2015-12-09 10:44:45
Chart #7 has tagged chart #4 for full recalculation. Chartbook: PreToPost.cht | 2015-12-09 10:44:45
HD Request # 24 | Decompressing data. | 2015-12-09 10:44:45
HD Request # 24 | Receiving Intraday data for DVOL-NYSE starting at 2015-12-09 10:35:57 | 2015-12-09 10:44:45
HD Request # 24 | Timestamp of first Intraday data file record written: 2015-12-09 10:35:58 | 2015-12-09 10:44:45
HD Request # 23 | Receiving historical Daily data for F.US.YMZ15 starting at 2015-12-07 | 2015-12-09 10:44:45
Writing historical Daily data for F.US.YMZ15 to the file F.US.YMZ15.dly | 2015-12-09 10:44:45
HD Request # 23 | Received 3 records from 2015-12-07 00:00:00 to 2015-12-09 00:00:00 (3.0 days) and wrote 2 records for F.US.YMZ15 | 2015-12-09 10:44:45
Socket (21) | Shutdown and closed. | 2015-12-09 10:44:45
HD Request # 23 | Daily download COMPLETE for F.US.YMZ15. Completion time: 0s. Unique request ID: 32 | 2015-12-09 10:44:45
Removed historical data download ID 32 | 2015-12-09 10:44:45
HD Request # 24 | Historical data for DVOL-NYSE is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-12-09 10:44:46
HD Request # 24 | Received 526 records from 2015-12-09 10:35:57 to 2015-12-09 10:44:42 (8.8 minutes) and wrote 525 records for DVOL-NYSE | 2015-12-09 10:44:46
HD Request # 24 | Intraday download COMPLETE for DVOL-NYSE. Completion time: 0s. Unique request ID: 18 | 2015-12-09 10:44:46
Removed historical data download ID 18 | 2015-12-09 10:44:46
HD Request # 25 | Downloading Historical Daily chart data for $DOWI. Starting date: 2015-12-07. Service: dow.index | 2015-12-09 10:44:46
HD Request # 25 | Requesting historical Daily data for $DOWI starting at 2015-12-06 | 2015-12-09 10:44:46
HD Request # 26 | Downloading Intraday chart data for ADR-TF to the file ADR-TF.scid. Service: statscalc | 2015-12-09 10:44:46
HD Request # 26 | Download start Date-Time: 2015-12-09 10:35:57.000 | 2015-12-09 10:44:46
HD Request # 26 | Using server: ds5.sierracharts.com port 10149 | 2015-12-09 10:44:46
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-12-09 10:44:46
F.US.EPZ15 Weekly #3 | Reloading chart. | 2015-12-09 10:44:46
$SPX Daily #1 | Reloading chart. | 2015-12-09 10:44:46
Socket (22) | Connected. | 2015-12-09 10:44:46
HD Request # 26 | Sending historical data logon request message. | 2015-12-09 10:44:46
HD Request # 26 | Requesting Intraday data. Start Date-Time: 2015-12-09 10:35:57. Record interval: 0. Symbol: ADR-TF | 2015-12-09 10:44:46
HD Request # 26 | Decompressing data. | 2015-12-09 10:44:46
HD Request # 26 | Receiving Intraday data for ADR-TF starting at 2015-12-09 10:35:57 | 2015-12-09 10:44:46
HD Request # 26 | Timestamp of first Intraday data file record written: 2015-12-09 10:35:58 | 2015-12-09 10:44:46
Socket (22) | Shutdown and closed. | 2015-12-09 10:44:46
The network socket for historical data has been closed. | 2015-12-09 10:44:46
HD Request # 25 | Receiving historical Daily data for $DOWI starting at 2015-12-07 | 2015-12-09 10:44:46
Writing historical Daily data for $DOWI to the file $DOWI.dly | 2015-12-09 10:44:46
HD Request # 25 | Received 3 records from 2015-12-07 00:00:00 to 2015-12-09 00:00:00 (3.0 days) and wrote 3 records for $DOWI | 2015-12-09 10:44:46
HD Request # 25 | Daily download COMPLETE for $DOWI. Completion time: 0s. Unique request ID: 33 | 2015-12-09 10:44:46
Removed historical data download ID 33 | 2015-12-09 10:44:46
HD Request # 26 | Historical data for ADR-TF is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-12-09 10:44:46
HD Request # 26 | Received 528 records from 2015-12-09 10:35:57 to 2015-12-09 10:44:44 (8.8 minutes) and wrote 527 records for ADR-TF | 2015-12-09 10:44:46
HD Request # 26 | Intraday download COMPLETE for ADR-TF. Completion time: 0s. Unique request ID: 19 | 2015-12-09 10:44:46
Removed historical data download ID 19 | 2015-12-09 10:44:46
HD Request # 27 | Downloading Historical Daily chart data for $VIX. Starting date: 2015-12-07. Service: cboe.index | 2015-12-09 10:44:46
HD Request # 27 | Requesting historical Daily data for $VIX starting at 2015-12-06 | 2015-12-09 10:44:46
HD Request # 28 | Downloading Intraday chart data for ADR-NASDAQ to the file ADR-NASDAQ.scid. Service: statscalc | 2015-12-09 10:44:46
HD Request # 28 | Download start Date-Time: 2015-12-09 10:35:57.000 | 2015-12-09 10:44:46
HD Request # 28 | Using server: ds4.sierracharts.com port 10149 | 2015-12-09 10:44:46
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-12-09 10:44:46
Socket (23) | Connected. | 2015-12-09 10:44:46
HD Request # 28 | Sending historical data logon request message. | 2015-12-09 10:44:46
HD Request # 28 | Requesting Intraday data. Start Date-Time: 2015-12-09 10:35:57. Record interval: 0. Symbol: ADR-NASDAQ | 2015-12-09 10:44:46
HD Request # 28 | Decompressing data. | 2015-12-09 10:44:46
HD Request # 28 | Receiving Intraday data for ADR-NASDAQ starting at 2015-12-09 10:35:57 | 2015-12-09 10:44:46
HD Request # 28 | Timestamp of first Intraday data file record written: 2015-12-09 10:35:58 | 2015-12-09 10:44:46
Socket (23) | Shutdown and closed. | 2015-12-09 10:44:46
HD Request # 27 | Receiving historical Daily data for $VIX starting at 2015-12-07 | 2015-12-09 10:44:46
Writing historical Daily data for $VIX to the file $VIX.dly | 2015-12-09 10:44:46
HD Request # 27 | Received 3 records from 2015-12-07 00:00:00 to 2015-12-09 00:00:00 (3.0 days) and wrote 3 records for $VIX | 2015-12-09 10:44:46
HD Request # 27 | Daily download COMPLETE for $VIX. Completion time: 0s. Unique request ID: 34 | 2015-12-09 10:44:46
Removed historical data download ID 34 | 2015-12-09 10:44:46
HD Request # 28 | Historical data for ADR-NASDAQ is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-12-09 10:44:46
HD Request # 28 | Received 528 records from 2015-12-09 10:35:57 to 2015-12-09 10:44:44 (8.8 minutes) and wrote 527 records for ADR-NASDAQ | 2015-12-09 10:44:46
HD Request # 28 | Intraday download COMPLETE for ADR-NASDAQ. Completion time: 0s. Unique request ID: 20 | 2015-12-09 10:44:46
Removed historical data download ID 20 | 2015-12-09 10:44:46
HD Request # 29 | Downloading Intraday chart data for ADR-YM to the file ADR-YM.scid. Service: statscalc | 2015-12-09 10:44:46
HD Request # 29 | Download start Date-Time: 2015-12-09 10:35:57.000 | 2015-12-09 10:44:46
HD Request # 29 | Using server: ds3.sierracharts.com port 10149 | 2015-12-09 10:44:46
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-12-09 10:44:46
$SPX Daily #2 | Reloading chart. | 2015-12-09 10:44:46
Socket (24) | Connected. | 2015-12-09 10:44:46
HD Request # 29 | Sending historical data logon request message. | 2015-12-09 10:44:46
HD Request # 29 | Requesting Intraday data. Start Date-Time: 2015-12-09 10:35:57. Record interval: 0. Symbol: ADR-YM | 2015-12-09 10:44:46
HD Request # 29 | Decompressing data. | 2015-12-09 10:44:47
HD Request # 29 | Receiving Intraday data for ADR-YM starting at 2015-12-09 10:35:57 | 2015-12-09 10:44:47
HD Request # 29 | Timestamp of first Intraday data file record written: 2015-12-09 10:35:58 | 2015-12-09 10:44:47
Socket (24) | Shutdown and closed. | 2015-12-09 10:44:47
The network socket for historical data has been closed. | 2015-12-09 10:44:47
HD Request # 29 | Historical data for ADR-YM is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-12-09 10:44:47
HD Request # 29 | Received 528 records from 2015-12-09 10:35:57 to 2015-12-09 10:44:44 (8.8 minutes) and wrote 527 records for ADR-YM | 2015-12-09 10:44:47
HD Request # 29 | Intraday download COMPLETE for ADR-YM. Completion time: 1s. Unique request ID: 21 | 2015-12-09 10:44:47
Removed historical data download ID 21 | 2015-12-09 10:44:47
HD Request # 30 | Downloading Intraday chart data for F.US.CLEF16 to the file F.US.CLEF16.scid. Service: cqg | 2015-12-09 10:44:47
HD Request # 30 | Download start Date-Time: 2015-12-09 10:32:54.000 | 2015-12-09 10:44:47
HD Request # 30 | Using server: ds5.sierracharts.com port 10149 | 2015-12-09 10:44:47
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-12-09 10:44:47
F.US.EPZ15 Daily #1 | Reloading chart. | 2015-12-09 10:44:47
Socket (25) | Connected. | 2015-12-09 10:44:47
HD Request # 30 | Sending historical data logon request message. | 2015-12-09 10:44:47
HD Request # 30 | Requesting Intraday data. Start Date-Time: 2015-12-09 10:32:54. Record interval: 0. Symbol: F.US.CLEF16 | 2015-12-09 10:44:47
F.US.EPZ15 Daily #5 | Reloading chart. | 2015-12-09 10:44:47
$SPX Weekly #2 | Reloading chart. | 2015-12-09 10:44:47
Socket (25) | Shutdown and closed. | 2015-12-09 10:44:47
HD Request # 30 | Historical data for F.US.CLEF16 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-12-09 10:44:47
HD Request # 30 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.CLEF16 | 2015-12-09 10:44:47
HD Request # 30 | Intraday download COMPLETE for F.US.CLEF16. Completion time: 0s. Unique request ID: 22 | 2015-12-09 10:44:47
Removed historical data download ID 22 | 2015-12-09 10:44:47
HD Request # 31 | Downloading Intraday chart data for F.US.USAH16 to the file F.US.USAH16.scid. Service: cqg | 2015-12-09 10:44:47
HD Request # 31 | Download start Date-Time: 2015-12-09 10:32:36.000 | 2015-12-09 10:44:47
HD Request # 31 | Using server: ds4.sierracharts.com port 10149 | 2015-12-09 10:44:47
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-12-09 10:44:47
$SPX Daily #3 | Reloading chart. | 2015-12-09 10:44:47
Socket (26) | Connected. | 2015-12-09 10:44:47
HD Request # 31 | Sending historical data logon request message. | 2015-12-09 10:44:47
HD Request # 31 | Requesting Intraday data. Start Date-Time: 2015-12-09 10:32:36. Record interval: 0. Symbol: F.US.USAH16 | 2015-12-09 10:44:47
Socket (26) | Shutdown and closed. | 2015-12-09 10:44:47
HD Request # 31 | Historical data for F.US.USAH16 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-12-09 10:44:47
HD Request # 31 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.USAH16 | 2015-12-09 10:44:47
HD Request # 31 | Intraday download COMPLETE for F.US.USAH16. Completion time: 0s. Unique request ID: 23 | 2015-12-09 10:44:47
Removed historical data download ID 23 | 2015-12-09 10:44:47
HD Request # 32 | Downloading Intraday chart data for F.US.GCEG16 to the file F.US.GCEG16.scid. Service: cqg | 2015-12-09 10:44:47
HD Request # 32 | Download start Date-Time: 2015-12-09 10:32:53.000 | 2015-12-09 10:44:47
HD Request # 32 | Using server: ds3.sierracharts.com port 10149 | 2015-12-09 10:44:47
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-12-09 10:44:47
Socket (27) | Connected. | 2015-12-09 10:44:47
HD Request # 32 | Sending historical data logon request message. | 2015-12-09 10:44:47
HD Request # 32 | Requesting Intraday data. Start Date-Time: 2015-12-09 10:32:53. Record interval: 0. Symbol: F.US.GCEG16 | 2015-12-09 10:44:47
Socket (27) | Shutdown and closed. | 2015-12-09 10:44:47
HD Request # 32 | Historical data for F.US.GCEG16 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-12-09 10:44:47
HD Request # 32 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.GCEG16 | 2015-12-09 10:44:47
HD Request # 32 | Intraday download COMPLETE for F.US.GCEG16. Completion time: 0s. Unique request ID: 24 | 2015-12-09 10:44:47
Removed historical data download ID 24 | 2015-12-09 10:44:47
HD Request # 33 | Downloading Intraday chart data for F.US.CLEG16 to the file F.US.CLEG16.scid. Service: cqg | 2015-12-09 10:44:47
HD Request # 33 | Download start Date-Time: 2015-12-09 10:32:51.000 | 2015-12-09 10:44:47
HD Request # 33 | Using server: ds5.sierracharts.com port 10149 | 2015-12-09 10:44:47
Socket (28) | Connected. | 2015-12-09 10:44:47
HD Request # 33 | Sending historical data logon request message. | 2015-12-09 10:44:47
HD Request # 33 | Requesting Intraday data. Start Date-Time: 2015-12-09 10:32:51. Record interval: 0. Symbol: F.US.CLEG16 | 2015-12-09 10:44:48
Socket (28) | Shutdown and closed. | 2015-12-09 10:44:48
The network socket for historical data has been closed. | 2015-12-09 10:44:48
HD Request # 33 | Historical data for F.US.CLEG16 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-12-09 10:44:48
HD Request # 33 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.CLEG16 | 2015-12-09 10:44:48
HD Request # 33 | Intraday download COMPLETE for F.US.CLEG16. Completion time: 0s. Unique request ID: 25 | 2015-12-09 10:44:48
Removed historical data download ID 25 | 2015-12-09 10:44:48
HD Request # 34 | Downloading Intraday chart data for F.US.TYAH16 to the file F.US.TYAH16.scid. Service: cqg | 2015-12-09 10:44:48
HD Request # 34 | Download start Date-Time: 2015-12-09 10:32:52.000 | 2015-12-09 10:44:48
HD Request # 34 | Using server: ds4.sierracharts.com port 10149 | 2015-12-09 10:44:48
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-12-09 10:44:48
Socket (29) | Connected. | 2015-12-09 10:44:48
HD Request # 34 | Sending historical data logon request message. | 2015-12-09 10:44:48
HD Request # 34 | Requesting Intraday data. Start Date-Time: 2015-12-09 10:32:52. Record interval: 0. Symbol: F.US.TYAH16 | 2015-12-09 10:44:48
Socket (29) | Shutdown and closed. | 2015-12-09 10:44:48
HD Request # 34 | Historical data for F.US.TYAH16 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-12-09 10:44:48
HD Request # 34 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.TYAH16 | 2015-12-09 10:44:48
HD Request # 34 | Intraday download COMPLETE for F.US.TYAH16. Completion time: 0s. Unique request ID: 26 | 2015-12-09 10:44:48
Removed historical data download ID 26 | 2015-12-09 10:44:48
HD Request # 35 | Downloading Intraday chart data for F.US.DXEZ15 to the file F.US.DXEZ15.scid. Service: cqg | 2015-12-09 10:44:48
HD Request # 35 | Download start Date-Time: 2015-12-09 10:32:54.000 | 2015-12-09 10:44:48
HD Request # 35 | Using server: ds3.sierracharts.com port 10149 | 2015-12-09 10:44:48
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-12-09 10:44:48
UVOL-NYSE [M] 15 Min #14 | Performing a full recalculation because it has been tagged. Chartbook: START.cht | 2015-12-09 10:44:48
Chart #15 has tagged chart #14 for full recalculation. Chartbook: START.cht | 2015-12-09 10:44:48
Chart #16 has tagged chart #14 for full recalculation. Chartbook: START.cht | 2015-12-09 10:44:48
Chart #17 has tagged chart #14 for full recalculation. Chartbook: START.cht | 2015-12-09 10:44:48
Chart #18 has tagged chart #17 for full recalculation. Chartbook: START.cht | 2015-12-09 10:44:48
Socket (30) | Connected. | 2015-12-09 10:44:48
HD Request # 35 | Sending historical data logon request message. | 2015-12-09 10:44:48
Chart #7 has tagged chart #6 for full recalculation. Chartbook: START.cht | 2015-12-09 10:44:48
Chart #19 has tagged chart #16 for full recalculation. Chartbook: START.cht | 2015-12-09 10:44:48
Chart #20 has tagged chart #15 for full recalculation. Chartbook: START.cht | 2015-12-09 10:44:48
Chart #21 has tagged chart #14 for full recalculation. Chartbook: START.cht | 2015-12-09 10:44:48
HD Request # 35 | Requesting Intraday data. Start Date-Time: 2015-12-09 10:32:54. Record interval: 0. Symbol: F.US.DXEZ15 | 2015-12-09 10:44:48
Socket (30) | Shutdown and closed. | 2015-12-09 10:44:48
HD Request # 35 | Historical data for F.US.DXEZ15 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-12-09 10:44:48
HD Request # 35 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.DXEZ15 | 2015-12-09 10:44:48
HD Request # 35 | Intraday download COMPLETE for F.US.DXEZ15. Completion time: 0s. Unique request ID: 27 | 2015-12-09 10:44:48
Removed historical data download ID 27 | 2015-12-09 10:44:48
Chart #30 has tagged chart #31 for full recalculation. Chartbook: START.cht | 2015-12-09 10:44:48
DVOL-NASDAQ [M] 15 Min #31 | Performing a full recalculation because it has been tagged. Chartbook: START.cht | 2015-12-09 10:44:48
Chart #31 has tagged chart #14 for full recalculation. Chartbook: START.cht | 2015-12-09 10:44:48
Chart #32 has tagged chart #14 for full recalculation. Chartbook: START.cht | 2015-12-09 10:44:48
Chart #33 has tagged chart #32 for full recalculation. Chartbook: START.cht | 2015-12-09 10:44:48
Chart #34 has tagged chart #35 for full recalculation. Chartbook: START.cht | 2015-12-09 10:44:48
DVOL-TF [M] 15 Min #35 | Performing a full recalculation because it has been tagged. Chartbook: START.cht | 2015-12-09 10:44:48
Chart #35 has tagged chart #14 for full recalculation. Chartbook: START.cht | 2015-12-09 10:44:48
F.US.YMZ15 Daily #7 | Reloading chart. | 2015-12-09 10:44:49
$DOWI Daily #8 | Reloading chart. | 2015-12-09 10:44:49
F.US.ENQZ15 Daily #2 | Reloading chart. | 2015-12-09 10:44:49
$NASX Daily #3 | Reloading chart. | 2015-12-09 10:44:49
F.US.TFEZ15 Daily #5 | Reloading chart. | 2015-12-09 10:44:50
$VIX Daily #9 | Reloading chart. | 2015-12-09 10:44:50
$RSC Daily #6 | Reloading chart. | 2015-12-09 10:44:50
CQG FIX: Sending the Logon message. | 2015-12-09 10:44:50
CQG FIX Trading | Connected to trading server. | 2015-12-09 10:44:50
CQG FIX Trading | Connecting to market data server api.cqg.com | 2015-12-09 10:44:50
CQG WebAPI | Connecting to websocket server. | 2015-12-09 10:44:50
CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35 | 2015-12-09 10:44:50
CQG FIX - FCM name: Dorman Trading | 2015-12-09 10:44:50
ADV-NYSE [M] 5 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: PreToPost.cht | 2015-12-09 10:44:51
UVOL-NYSE [M] 15 Min #14 | Performing a full recalculation because it has been tagged. Chartbook: START.cht | 2015-12-09 10:44:52
UVOL-NASDAQ [M] 15 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: START.cht | 2015-12-09 10:44:52
Chart #15 has tagged chart #14 for full recalculation. Chartbook: START.cht | 2015-12-09 10:44:52
UVOL-TF [M] 15 Min #16 | Performing a full recalculation because it has been tagged. Chartbook: START.cht | 2015-12-09 10:44:52
Chart #16 has tagged chart #14 for full recalculation. Chartbook: START.cht | 2015-12-09 10:44:52
ADV-NYSE [M] 5 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: START.cht | 2015-12-09 10:44:52
UVOL-YM [M] 15 Min #17 | Performing a full recalculation because it has been tagged. Chartbook: START.cht | 2015-12-09 10:44:52
Chart #17 has tagged chart #14 for full recalculation. Chartbook: START.cht | 2015-12-09 10:44:52
DVOL-NYSE [M] 15 Min #32 | Performing a full recalculation because it has been tagged. Chartbook: START.cht | 2015-12-09 10:44:52
Chart #32 has tagged chart #14 for full recalculation. Chartbook: START.cht | 2015-12-09 10:44:52
UVOL-NYSE [M] 15 Min #14 | Performing a full recalculation because it has been tagged. Chartbook: START.cht | 2015-12-09 10:44:53
CQG WebAPI websocket (31) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-12-09 10:44:57
CQG WebAPI websocket (31) | Shutdown and closed. | 2015-12-09 10:44:57
CQG FIX Trading | Websocket closed. | 2015-12-09 10:44:57
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-12-09 10:44:57
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-12-09 10:44:57
CQG FIX: DisconnectFIX called. | 2015-12-09 10:44:58
CQG FIX: Sending a Logout message. | 2015-12-09 10:44:58
CQG FIX Trading | Disconnected. | 2015-12-09 10:44:58
CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2015-12-09 10:44:58
socket (20) | Shutdown and closed. | 2015-12-09 10:44:58
CQG FIX: Disconnected. | 2015-12-09 10:44:58
HTTP connection to ds01.ddfplus.com:80 (6) | Closed. No error. | 2015-12-09 10:45:51
HTTP connection to ds01.ddfplus.com:80 (6) | Shutdown and closed. | 2015-12-09 10:45:51
[2015-12-09 16:37:44]
There was a problem with the CQG market data server but it is now resolved.
[2015-12-09 16:39:22]
AP - Posts: 117
ok thanks - how often does this happen?
[2015-12-09 16:45:05]
You will know better how often this happens than us. The problem was with the CQG server that we do not control and obviously it just happened.
When else has it happened?
[2015-12-09 16:49:08]
AP - Posts: 117
I do not mean to be critical.
Just that this never happened before. And I just wanted to assess such latency risks.
[2015-12-09 18:15:08]
This is why we asked. We are aware of of incidents like this before, but it may not have been at times that were critical for you.
Have a look at this posting here:
CQG Data Feed Outage Today
Date Time Of Last Edit: 2015-12-09 18:15:27
