Date/Time: Thu, 26 Dec 2024 06:47:52 +0000
Access Rithmic's NYSE TICK data
View Count: 3156
[2015-12-09 12:01:16]
User723043 - Posts: 11
I'm currently using the symbol "TICK-NYSE" for the market internal streaming on SC + Rithmic data feed and since I do not feel comfortable with the reading criteria of these data, I ask if I can use an alternative symbol (which I do not find in the markets internals list) as to Rithmic Tick symbol.
Thank you in advance.
[2015-12-09 16:34:29]
You can use that symbol but we do not know what it is.
[2015-12-09 18:37:12]
Thanks for the reply. I still did not understand what solution to adopt and then I try to rephrase the question more clearly. "Using SC with Rithmic, what are the symbols for the NYSE Tick that are active in my platform and that I can use? In which section can I find them? In the" Market Stats "I see only the symbol" NYSE-TICK "that, if I'm not mistaken, It's owned by Sierra.
See attached file
imageCattura.JPG / V - Attached On 2015-12-09 18:36:13 UTC - Size: 71.86 KB - 535 views
[2015-12-09 18:54:47]
What is the Rithmic TICK symbol?
You are not limited to the symbols listed in the Find Symbol window. You can manually type in any symbol in the Selected Symbol box and open a chart for it.
