Date/Time: Sun, 13 Sep 2026 10:19:58 +0000
KOSPI and other index data
View Count: 1908
| [2015-12-08 21:16:57] |
| EuropeanTrader - Posts: 290 |
Hi, I chose SC historical data and KSZ15 contract intraday but it doesnt show any data. What am I missing here? I thought delayed data will be displayed. Same goes for Nikkei from Osaka NOZ15. Also, I cant find Australian stock index futurs ASX200. Pls help me find the symbol. Thank you. |
| [2015-12-09 17:25:04] |
If you do not receive historical Intraday data for KSZ15 or NOZ15, then it is not available. You will only be able to get Historical Daily charts for these symbols. For the stock index futures use the symbol that begins with AP. You will find it in File >> Find Symbol >> Futures-Indices. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-12-09 17:25:32
| [2026-02-21 14:26:09] |
| TonyCipriani - Posts: 151 |
Hi, I was wondering if we can please get KOSPI live data using FXCM's CFD data. It has one of the most liquid options in the world. Thanks! |
| [2026-02-23 15:33:44] |
| John - SC Support - Posts: 47854 |
We checked the FXCM website to see if they have a KOSPI index CFD, and we are not seeing it. If you can point us to their information for it, then we can see if it is available with the current data we get from them.
| [2026-02-23 19:35:09] |
Sorry, you're right, they don't have it. I just called them and put in a request for it. I'll let you know if they do end up adding it. Thanks. |
