Date/Time: Thu, 26 Dec 2024 04:20:35 +0000
TRIN calculation and documentation definition
View Count: 2899
[2015-12-08 21:11:54] |
User13668 - Posts: 294 |
Can you please check that your software is applying the correct formula for the TRIN Market Statistics calculation. For one thing I certainly believe the documentation INCORRECTLY describes the formula (Sierra Chart Market Statistics: Symbols). Here are three external references for the formula which are all the same and are different to your documented formula: http://stockcharts.com/school/doku.php?id=chart_school:technical_indicators:trin https://en.wikipedia.org/wiki/TRIN_(finance) http://www.investopedia.com/terms/a/arms.asp So naturally I wondered that if the documentation is wrong, is the actual software formula also wrong as I am not getting plots for the S&P500 TRIN that you would expect for the price movement ie what these external 3 sites suggest TRIN should look like in certain market conditions. Thanks |
[2015-12-08 21:48:40] |
The documentation explains the formula in 2 places and in one place it was incorrectly stated but it is now corrected with the correct formula as actually implemented. Reference Sierra Chart Market Statistics: Symbols We have examined the calculation method in our software and it is correct. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
