Date/Time: Thu, 26 Dec 2024 04:39:10 +0000
DAX quoteaboard
View Count: 704
[2015-12-08 20:57:54]
rhovega - Posts: 279
My quoteboard is not displaying DAX anymore (DAX-201512-DTB), even though I can chart it intraday without a problem. Would you know what may be the issue? Thanks.
[2015-12-08 21:03:14]
You need to use the new symbol format.
In the Quote Board you will find it in Settings >> Set Symbols >> [select existing symbol] >> Find >> Futures.
Date Time Of Last Edit: 2015-12-08 21:04:02
