Date/Time: Thu, 26 Dec 2024 05:03:26 +0000
verical grid lines
View Count: 708
[2015-12-08 17:25:07]
User160670 - Posts: 19
hi. i have an intraday range bar chart. i plotted a 15 min vertical grid lines. is there any way to get reed of the ones that are in the right edge, that means in the future? thanks in advanced.
[2015-12-08 18:31:10]
They will be displayed past the last bar in the chart. You just need to scroll past the last bar in the chart. Refer to:
https://www.sierrachart.com/index.php?page=doc/doc_WorkingWithCharts.html#ScrollingTheChart
