Date/Time: Thu, 26 Dec 2024 04:15:19 +0000
How to display Time Range Highlight in horizontal format
View Count: 725
[2015-12-08 16:44:49] |
User592524 - Posts: 5 |
Hello Support I've marked off the London (3:00am EST in green) and New York Open (8:00am EST in grey) using the Time Range Highlight Indicator. How do I display it as horizontal lines rather than vertical format. I've attached the image for reference Thank you Date Time Of Last Edit: 2015-12-08 16:53:30
Private File |
[2015-12-08 17:12:00] |
This kind of Draw Style with that study is not supported.
