Date/Time: Thu, 17 Sep 2026 08:15:21 +0000
TPO Charts: Daily TPO and only X days of Evening TPO
View Count: 1403
| [2015-12-08 16:10:34] |
| User13642 - Posts: 21 |
I would like to create a TPO chart that shows the last 90 days of day session profiles, but only the last 3 days of the evening session. Every time I turn on the evening session, no matter what I try, I get the evening session for all profiles in the chart. Am I missing something, or is there a function to choose to show only the last X days of evening session profiles? Thanks! -Mike |
| [2015-12-08 17:15:42] |
The only way you are going to be able to do something like this is if you only display 1 Day TPO Profiles and use the split functionality to split out the evening session from the last 3 TPO Profiles. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_TPOVolProfileCharts.html#SplitMerges However, all TPO Profiles will need to contain the full 24 hours or trading. But you can split out the evening session from the last three. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-12-08 17:16:20
| [2015-12-08 17:22:53] |
Thanks, but I don't want all of the other profiles to have 24 hours of trading. Oh well. -Mike |
| [2015-12-08 17:46:07] |
Therefore, there is no way you can accomplish what you want. You will have to use two separate charts. That is the only possibility.
| [2015-12-08 17:47:17] |
That's what I've been doing - thanks. -Mike |
