Date/Time: Thu, 26 Dec 2024 05:01:11 +0000
SC and IB
View Count: 726
[2015-12-08 06:01:33] |
stephensmart - Posts: 51 |
Hi, i am trading through SC with IB as broker, using the SC DOM when i am in a position the P/L changes and i can see orders on DOM, however when the position is closed it does not display on the Day column, that just shows nothing.
[2015-12-08 07:14:51] |
What is?: "Day column". Maybe you are referring to the Daily P/L field : http://www.sierrachart.com/index.php?page=doc/doc_DailyProfitLossValue.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-12-08 07:15:09
[2015-12-08 07:48:13] |
yes that is what i am referring to on the DOM.
[2015-12-08 08:37:22] |
Ok issue has been resolved, thanks.
