Date/Time: Thu, 26 Dec 2024 05:01:53 +0000
How to do three tier color based on slope
View Count: 797
[2015-12-07 22:07:47] |
User380760 - Posts: 88 |
I'd like to do the color based on slope like the following: - if the slope is > certain limit (say 1% degree), green - if the slope is < certain limit (say -1% degree), red - if the slope is in betw, then gray. How can I do that? Thanks! |
[2015-12-08 03:39:59] |
For this you will need to use the Color Bar Based on Alert Condition study: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s245 And the Study Angle Study: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s231 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
