Date/Time: Thu, 26 Dec 2024 15:50:30 +0000
SC Historical Data
View Count: 1038
[2015-12-07 15:19:03] |
User59228 - Posts: 47 |
Hi, the historical data Service is very nice. I tested the INX-Index with intraday data back to 2008. Now I will test the Nasdaq 100 Index, but I only find the $NDXT-Index back for this year. Is it possible to get longer data for the NDX 100 ? Thank you
[2015-12-07 17:18:32] |
The symbol for the NASDAQ 100 is: $IUXX Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-12-07 18:24:34] |
Thank you. I tried this symbol too but I got only data for a few month. How Long should the history be ?
[2015-12-08 03:03:34] |
There should be at least 4 years of data for that symbol. Follow the instructions here: https://www.sierrachart.com/index.php?page=doc/doc_HistoricalIntradayData.html#DownloadingViewingMoreHistoricalIntradayData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-12-08 03:03:48
[2015-12-08 08:27:12] |
Now it works, thank you.
[2015-12-14 13:36:43] |
Hi, I have a further question. It it possible to get historical data for the German Share Index DAX. I donĀ“t find the Dax-Index, only the future. Thank you
[2015-12-14 18:26:16] |
Are you using Interactive Brokers? If so, the symbol is DAX-IND-DTB. It is in File >> Find Symbol >> Interactive Brokers Indexes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-12-14 18:42:12
[2015-12-14 18:46:06] |
Yes,IB is my Broker. But I search historical data and then i look at the instance SC Historical Data and there at Indexes.
[2015-12-14 18:50:03] |
You can definitely get this data in the instance of Sierra Chart connected to Interactive Brokers by using the DAX-IND-DTB symbol. In the instance of Sierra Chart connected to SC Historical Data you can use the symbol GER30 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-12-14 19:05:39] |
Sorry, but in the instance of Sierra Chart i cannot find the Symbol GER30. I looked at the Indexes-List.
[2015-12-14 19:11:53] |
You will see this in File >> Find Symbol >> CFD.
[2015-12-14 19:37:47] |
Ok, but can I get historical data from IB with the Symbol DAX-IND-DTB or are the data from SC Historical Data (GER30) longer ?
[2015-12-14 20:05:12] |
You can use either symbol. It will be easiest to get long-term historical data using the symbol GER30.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-12-14 20:21:26
[2015-12-14 20:23:20] |
ok, thank you.
