Date/Time: Thu, 16 Jan 2025 06:09:05 +0000
ZigZag Tick Length in Spreadsheet?
View Count: 2172
[2015-12-07 06:15:35] |
Halco - Posts: 92 |
ZigZag has the option of showing each swing length in ticks. Is it possible to put that data into a spreadsheet? Thanks.
[2015-12-07 06:24:05] |
User60518 - Posts: 106 |
I asked exactly the same last week - here's a link to the documentation: https://www.sierrachart.com/index.php?page=doc/doc_SpreadsheetAdditionalInfo.html#ExportingSheetDataToTextFile are you by any chance going through Kam's 18 module course? Cheers Date Time Of Last Edit: 2015-12-07 06:33:30
[2015-12-07 08:06:08] |
Looks like the answer in post #2 answers your question. Let us know if you need more help.
[2015-12-07 08:30:54] |
Halco - Posts: 92 |
Sorry, I must be doing something wrong. I do not see a column in the spreadsheet with that data. In Inputs I have Based On: ZigZag and I have Output Additional Inputs... set to Yes. I can't figure out what else I need to do. Date Time Of Last Edit: 2015-12-07 09:09:34
[2015-12-07 15:14:33] |
Halco - Posts: 92 |
Got it. I didn't have "Additional Output for Spreadsheets" set to Yes. Now I've done that, it's working. Thanks User60518 for your response. No, I'm not taking that course. |
[2017-10-13 02:41:13] |
Clef - Posts: 11 |
Hi, I want to export swing high low data of zig zag line (length of zig zag line) in a spreadsheet, just as requested by the user in the post#1. The spreadsheet gave all the tick data as the output, but I am interested only in the length of the zig zag line data. I followed the steps in post #5, however, I still cannot get the data for the zig zag swing high and low. |
[2017-10-16 21:53:37] |
This is still pending review.
[2017-10-17 07:03:01] |
You do need to set the Additional Output for Spreadsheets Input to Yes with the ZigZag study. However, also refer to the documentation for that here: Zig Zag: Additional Output for Spreadsheets But the ZigZag Line Length only has a value at each ZigZag line end point. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
