Date/Time: Tue, 22 Sep 2026 22:56:01 +0000
Issues with 2 symbols on same chart each with their own studies painted on the region
View Count: 1164
[2015-12-06 18:43:15]
KhaosTrader - Posts: 128
I want to put 2 symbols on the same chart, actually, Its the same symbol twice , I used an overlay study based on the same chart to draw the bars in region 2. I then put in different indicators for each region, where each indicator is set to the particular "based on" input. The problem is scaling, on the overlay subgraph i can move the price bars, but the corresponding indicators on that subgraph wont move, so the price bars are out of sync with the various drawn studies on it. I need to either make the studies move with the price or lock the price such that it cant move so that the studies that are painted on the subgraph overlay wont get out of scale. How do I accomplish this?
[2015-12-06 18:47:56]
I just figured it out, I think. I just go to the subgraph, click on Settings, and inputs, then click on scale and select "same as region". this locks it, I think, is this the best way to do what i want?
[2015-12-08 07:02:12]
All of the Studies in the same Chart Region that you want to share the same scale with need to have a Scale Range of "Automatic".
Date Time Of Last Edit: 2015-12-08 07:02:28
