Date/Time: Thu, 24 Sep 2026 13:57:23 +0000
AMP Futures version of Sierra Chart
View Count: 1489
| [2015-12-05 22:57:26] |
| User967815 - Posts: 9 |
Does their version of Sierra allow for multiple installs? I have a PC that I will use most of the time but I also need to be able to use Sierra on my laptop when I am on the move. Is this possible? Thanks
| [2015-12-07 05:21:35] |
| bekitz3 - Posts: 83 |
You can install Sierra on 1000 computers if you have them. But with a broker provided login (such as with AMP futures) you will only be able to login to one instance at a time. So you can login on your laptop as long as you are not logged in on your desktop. So it will work for the scenario you described. This is one of the main differences between broker provided copy vs. Sierra direct account. With a direct account you can be logged on to as many copies as you want on the same computer and also be logged in across 2 computers simultaneously. |
