Date/Time: Fri, 11 Sep 2026 17:33:51 +0000
Chart Settings > Main Settings > Tick Size
View Count: 1244
| [2015-12-04 21:06:52] |
| User850090 - Posts: 27 |
Why is Tick Size always come back to 0.010000 when I change symbols in my chart? Why it wont stay the same? It always mess up my chart. Thanks
| [2015-12-04 23:09:11] |
| Sawtooth - Posts: 4352 |
Go to Global Settings >> Symbols Settings and set the Tick Size you want.
| [2015-12-06 10:46:11] |
What you need to do is set the Tick Size to what you require for the symbol or symbol pattern for the symbols you are changing the chart to, in Global Symbol Settings: Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
