Date/Time: Thu, 17 Sep 2026 19:00:38 +0000
Execution and Trade activity log
View Count: 1069
| [2015-12-04 15:40:30] |
| EuropeanTrader - Posts: 290 |
Hello, I have live FXCM FIX and have no positions opened currently. However "Trade Activity Log" doesn't show "Exit date time" of the last trade and exit quantity is not the same as entry quantity suggesting I still have a trade on. Can you please check? Thank you. |
| [2015-12-04 18:08:41] |
You will need to insert the missing order fill. Refer to: Trade Activity Log: Missing Order Fills from Trade Activity Log We have no ability to check or control this on our side. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
