Date/Time: Thu, 26 Dec 2024 03:47:06 +0000
Cascading trend lines
View Count: 1116
[2015-12-03 23:44:02] |
ldrews - Posts: 9 |
I use multiple time frame charts of the same instrument. I would like the trendlines, support/resistance lines of the higher timeframe chart to show up on the lower timeframe chart. Is there a way to do this?
[2015-12-04 04:00:05] |
Yes, refer to: https://www.sierrachart.com/index.php?page=doc/helpdetails72.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-12-07 05:24:04] |
bekitz3 - Posts: 83 |
In my experience, this solution is not consistently accurate for any lines/drawing tools with a angle/slope to them (trendlines, pitchforks, etc). It's fine for horizontal & vertical lines though.
[2015-12-07 05:45:47] |
Yes, the information given in post #3 is correct.
