Date/Time: Fri, 18 Sep 2026 08:25:46 +0000
Grid Lines
View Count: 1192
| [2015-12-03 00:11:30] |
| MKL17 - Posts: 35 |
I am noticing that when I select a set scale increment the gridlines do not match up to the increments which is kind of disconcerting visually. I have only just recently noticed this occuring and was wondering if there is something I can change so that gridlines line up with the values scale. I cannot find any documentation relating to this. Thanks.
| [2015-12-03 00:19:38] |
Provide an image of the chart, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-12-03 01:23:30] |
| MKL17 - Posts: 35 |
http://www.sierrachart.com/image.php?l=1449105776711.png here is a chart image where numbers dont align with gridlines |
| [2015-12-03 04:11:52] |
Set the Horizontal Grid Line Increment in the Scale Settings window to 5 as well: Chart Scale and Scale Adjusting: Opening the Scale Settings Window for the Main Price Graph We have tested this now and verified that this works properly. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
