Date/Time: Thu, 26 Dec 2024 04:33:19 +0000
Left Side Scale Enabled, but it's blank - any idea why?
View Count: 866
[2015-12-02 21:59:07] |
infpz - Posts: 826 |
See image - thanks.
[2015-12-02 22:16:06] |
It would be easiest for us to get the Chartbook to examine why this is the case. It can be attached here by following these instructions: Support Board Posting Information: Attaching a File (Optional) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-12-03 20:14:57] |
Attached
Private File |
[2015-12-03 22:00:41] |
We see the problem and we will see how to solve this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-12-04 04:47:59
[2015-12-07 17:07:24] |
The customer thinks it might have something to do with the time range highlight studies; when I removed them all, the left scale comes back.
[2015-12-07 17:18:56] |
Yes the problem is from those.
