Date/Time: Sat, 19 Sep 2026 22:41:07 +0000
Diff between buying a feed from SC vs Broker
View Count: 1139
| [2015-12-02 19:31:01] |
| AP - Posts: 117 |
Is there any merit in buying the market data real time feed from SC than from the broker? Please, will appreciate if you took some time and elaborated benefits, if any, in buying it directly from SC. |
| [2015-12-02 22:00:51] |
We see you are using CQG for market data. If you do not have any issues with the CQG market data feed, then there is not any real practical advantage. If you are having issues with the CQG data feed, the most likely using the Sierra Chart Exchange Data Feed will resolve those. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-12-03 02:10:28] |
| AP - Posts: 117 |
Can I use CQG for order routing and other market data while SC for the indices market data under the CQG link information in the DTS tab?
| [2015-12-03 05:02:42] |
Yes. This is explained here: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#Integration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
