Date/Time: Thu, 26 Dec 2024 06:55:22 +0000
alphabetical order in HC
View Count: 745
[2015-12-02 16:00:12] |
Ed Meckelborg - Posts: 71 |
As I click on HC to open up a chart for a specific stock they are not listed in alphabetical order. It's a jumbled mess. Can this list be put in alphabetical order. Thanks |
[2015-12-02 17:54:43] |
After opening the File Open window, left click on the "File Name" header in the list of files to sort it. Each time you left click, it will sort between ascending and descending.
[2015-12-08 22:52:57] |
Tried many times but I cannot get the job done. Is there something missing ? |
