Date/Time: Wed, 25 Dec 2024 19:11:50 +0000
Price Change in Tool Values Window
View Count: 748
[2015-12-02 10:28:06] |
tobi - Posts: 351 |
Since version 1332 it show's the Price Change in the Tool Values Window. How can this be disabled? |
[2015-12-02 10:30:43] |
It cannot be.
[2015-12-02 10:40:16] |
tobi - Posts: 351 |
That ist annoying and these are changes in the wrong direction. The items in the Tool Values Window should be getting more choosable/adjustable. What you are doing ist adding items (that some people don't need/want) and thus makes the TVW bigger. It would be perfect if all items that one wants to see would be choosable. |
