Date/Time: Wed, 25 Dec 2024 18:50:34 +0000
Sugar SB historical data
View Count: 662
[2015-12-02 00:29:29] |
brown555 - Posts: 35 |
Hey guys - I'm only getting 2 years of data - any chance I could get more? Most others I get about 10 yrs it seems - http://www.sierrachart.com/image.php?l=1449016021398.png |
[2015-12-02 02:11:09] |
The problem is there are no rollover rules which were set up for this symbol for Interactive Brokers. This is now done. Update the Symbol Settings as explained here: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettingsSteps When that is done go to the chart and select Chart >> Reload and Recalculate. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-12-02 02:13:17
