Date/Time: Wed, 30 Oct 2024 22:55:53 +0000
Volume profile
View Count: 1880
[2013-06-21 08:20:00] |
OtaTrader - Posts: 5 |
Hi, can you please help me with Volume profile settings? I am not able to set two separate volume profiles. The first one is starting at 8:00 and end at 15:30 and the second one goes from 15:30 to 00:00. Thank you |
[2013-06-21 10:39:53] |
Zosimus - Posts: 345 |
If the hours between 00:00 to 8:00 are not important for you then you can do the following: In the Chart Settings (Chart>>Chart Settings) enter 8:00 for Start Time and 15:30 for End Time. Then check the box near "Evening Session(Optional)" and enter 15:30 for the Evening Start and 00:00 for Evening End. Click Apply and Ok. Now go to your Volume by price study settings and choose: Fixed by Time for the Volume Graph Period Type. Days for the Time Period Type for Fixed by Time. 1 for Time Period Length for Fixed by Time. Yes for Use Separate Profile for Evening Session. Date Time Of Last Edit: 2013-06-21 23:37:28
[2013-06-21 23:37:18] |
The instructions given in post #2 are correct. Thank you. Here are the general instructions for using the Volume by Price study: https://www.sierrachart.com/index.php?l=doc/doc_VolumeByPrice.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-06-24 07:09:21] |
Thank you, however this doesn't solve my issue. Is there a way how to set up three different profiles? (Sorry that I previously asked for two). I need it for trading 6E. Times: 1. profile 22:15-8:59, 2. profile 9:00-15:29, 3. profile 15:30-22:14 Thank you and have a great day. |
[2013-06-25 00:21:31] |
Not exactly. Please refer to the Volume by Price documentation for the available Volume Graph Period Types that you can use.
