Date/Time: Sat, 19 Sep 2026 14:23:27 +0000
EUREX DAX / Mini-DAX
View Count: 4502
| [2015-12-01 09:22:25] |
| User39772 - Posts: 311 |
Hello, I activated EUREX RT Data Feed. No RT feed seems to be available, it seems that SC tries to load data from my broker (IB) not from SC. Which Symbols do I have to use if I want to display tha data the DAX future and the Mini Dax future via SC data feed ? How can I choose the different contracts in SC, e.g. september / december / continuous contracts etc. What do I have to do if I want to send orders from SC to IB for these contracts ? |
| [2015-12-01 09:54:44] |
You just need to update to the current version of Sierra Chart by following the instructions here: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate These are the symbols you need to use in File >> Find Symbol: DAX-201603-DTB-EUR-25 DAX-201603-DTB-EUR-5 You can chart and trade using these symbols. And the data will come from the Sierra Chart Exchange Data Feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-12-01 10:40:03] |
When I enter the symbols into an existing Chart [R] that also receives data from other symbols via SC remote instance, nothing happens. If I use Find-Symbol, go to my Brokers instance (noch SC) and select the data I see a chart marked with [M]. How do I know if I see data from my broker or from SC ?
| [2015-12-01 10:45:08] |
[M] means the data is coming from the Sierra Chart data feed.
| [2015-12-01 14:59:24] |
In the message log I see the following message repeating over and over again: Using username 0 | 2015-12-01 14:57:44 SC Exchange Data | Connecting to the server scdf1.sierracharts.com. Port 10046 | 2015-12-01 14:57:44 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-12-01 14:57:44 Socket (733) | Connected. | 2015-12-01 14:57:45 SC Exchange Data | Connected to server. | 2015-12-01 14:57:45 SC Exchange Data | Setting DTC Encoding to Binary | 2015-12-01 14:57:45 SC Exchange Data | Sending logon request message. | 2015-12-01 14:57:45 SC Exchange Data | Server Name: SC Real-Time Server. | 2015-12-01 14:57:45 SC Exchange Data | Server protocol version: 7. Client protocol version: 7 | 2015-12-01 14:57:45 SC Exchange Data | Logon error received from server: Limited to one connection per username for the requested data source. | 2015-12-01 14:57:45 Socket (733) | Shutdown and closed. | 2015-12-01 14:57:45 SC Exchange Data | Disconnected from the server. | 2015-12-01 14:57:45 SC Exchange Data | Data feed disconnected. Will reconnect. | 2015-12-01 14:57:45 Using username 0 | 2015-12-01 14:57:47 SC Exchange Data | Connecting to the server scdf2.sierracharts.com. Port 10047 | 2015-12-01 14:57:47 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-12-01 14:57:47 Socket (734) | Connected. | 2015-12-01 14:57:47 SC Exchange Data | Connected to server. | 2015-12-01 14:57:47 SC Exchange Data | Setting DTC Encoding to Binary | 2015-12-01 14:57:47 SC Exchange Data | Sending logon request message. | 2015-12-01 14:57:47 SC Exchange Data | Server Name: SC Real-Time Server. | 2015-12-01 14:57:47 SC Exchange Data | Server protocol version: 7. Client protocol version: 7 | 2015-12-01 14:57:47 SC Exchange Data | Logon error received from server: Limited to one connection per username for the requested data source. | 2015-12-01 14:57:47 Socket (734) | Shutdown and closed. | 2015-12-01 14:57:47 SC Exchange Data | Disconnected from the server. | 2015-12-01 14:57:47 SC Exchange Data | Data feed disconnected. Will reconnect. | 2015-12-01 14:57:47 |
| [2015-12-01 17:37:35] |
This is the relevant error message: SC Exchange Data | Logon error received from server: Limited to one connection per username for the requested data source. | 2015-12-01 14:57:47 You either need to use the Sierra Chart Exchange Data Feed from one instance of Sierra Chart or activate additional real-time data connections. This is explained here: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#Connections Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-12-11 13:47:22] |
Are there any limitations for the Mini-Dax regarding the backfill of data (DAX-201603-DTB-EUR-5) ? For the *-EUR-25 contract I get much more data compared to the Mini-Version (same expiration data). Or ist there is also a Continuous version available (i.e. independent from the expiration date) ? |
| [2015-12-11 17:36:56] |
The mini DAX futures contract only started trading about a month ago. So that is about all the historical data that is available. The Continuous Futures Contract feature does work with that symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
