Date/Time: Sat, 23 Nov 2024 05:25:40 +0000
Downloading Upgrade error
View Count: 1706
[2013-06-21 06:31:44] |
PhilipJames - Posts: 34 |
Hi I got this error: http://screencast.com/t/5kMlkBue14 Could you please let me know what is wrong and how it can be solved? Thanks! |
[2013-06-21 07:19:38] |
This is caused by a firewall on your system. Please refer to this section for help with this: http://www.sierrachart.com/index.php?l=doc/LoginInstructions.php#LoginProblems Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
