Date/Time: Wed, 25 Dec 2024 17:47:51 +0000
global setting
View Count: 840
[2015-11-30 20:28:03] |
User638756 - Posts: 52 |
Is there a way I can set all my new charts to open with candlestick bars and a horizontal grid so I dont have to manually put them in each chart? Thanks a bunch |
[2015-11-30 20:38:17] |
Refer to this page for instructions: http://www.sierrachart.com/index.php?page=doc/helpdetails20.html The documentation explains how to set the default for the Graph Draw Type but for both of these settings mentioned, you do need to use the Duplicate Chart functionality. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-11-30 20:43:53] |
I have refereed to this multiple times and still no luck "20.3: Setting Default Chart Settings For New Charts" I dont know what im doing wrong Thanks |
[2015-11-30 20:58:04] |
It is not possible to set a default setting for the Horizontal Grid. So you need to use one of the existing charts that has that set and select Chart >> Duplicate Chart. Refer to: http://www.sierrachart.com/index.php?page=doc/helpdetails20.html#DuplicatingCharts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-11-30 21:06:17] |
Ok great, Thanks for your help. I found what I was doing wrong on the candle sticks also. Have a great day! |
