Date/Time: Wed, 25 Dec 2024 19:09:18 +0000
Order Fill Info on multiple charts
View Count: 1232
[2015-11-30 18:40:13]
User842703 - Posts: 55
Is it possible to filter "Show Order Fills" info on charts with the same symbol but different time frames in different chart books. For example I have Day Trading and Swing Trading chartbooks using the same symbols and don't want the trades made on a 3min chart to show on the 120min chart. I know you can set show order fill info on/off but that applies globally.
[2015-12-01 08:31:56]
This is a question not a discussion.
[2015-12-01 08:43:12]
This is not supported. It is not an area of development that Sierra Chart would get involved with.
We also assume that you understand that the Trade >> Show Order Fills option is specific to each individual chart?
Date Time Of Last Edit: 2015-12-01 08:44:54
[2015-12-01 08:54:12]
Ok just to clarify. I'm trying to find a solution to this:
http://www.sierrachart.com/image.php?l=1448959850917.png
It shows all the fills from a different chartbook & timeframe when toggling "Show Order Fills"
[2015-12-01 09:47:01]
OK, therefore just simply uncheck Trade >> Show Order Fills. You can add a Control Bar button to the Control Bar to easily enable and disable this option:
https://www.sierrachart.com/index.php?page=doc/doc_GlobalSettingsMenu.html#CustomizeToolbar
Refer to the documentation here for settings which control what is displayed for an order fill:
https://www.sierrachart.com/index.php?page=doc/doc_GlobalTradeSettings.html#ChartTradeSettings
[2015-12-01 10:40:26]
I've actually already done that but the issue is whether its possible to filter the fills for trades placed on a specific chart template. In the example above by unchecking Trade >> Show Order Fills I lose all trade info but I want to show trades placed on that particular chart and not all the others placed in a different chart/chartbook.
[2015-12-01 17:41:47]
OK we understand what you want, and when the Trade >> Only Orders from Chart is enabled, then only order fills that are for orders which originated from the chart will be displayed on the chart.
This will be out in the next release.
