Date/Time: Wed, 25 Dec 2024 17:58:56 +0000
three questions
View Count: 832
[2015-11-30 16:46:21]
markuz - Posts: 90
When showing separate evening and RTH session profiles on the same chart, how can I color code the evening session profiles differently than the RTH profiles?
For the Volume by price study. On my TPO chart, I only want to display volume for the current TPO session. When I try to change it in settings, it will always revert back to "Base on TPO chart"
I want the advance decline line, not the ADR "ratio" for market internal. Is this possible?
[2015-11-30 17:35:29]
1. Are you referring to TPO Profiles? Look at the TPO Letter/Block Colors setting. Here is the documentation for it:
https://www.sierrachart.com/index.php?page=doc/doc_TPOVolProfileCharts.html#TPOLetterBlockColors
Use the Use Letter/Block Color 1-18 for Periods setting. You can then use 2 color settings for the 18 color settings and alternate them.
2. This cannot be changed. This capability will be added but we are not sure when we can get to it.
3. Yes this can be done. Refer to the Symbols section here:
Sierra Chart Market Statistics: Symbols
Specifically to the NISS-* symbol.
Date Time Of Last Edit: 2015-11-30 17:37:06
