Date/Time: Tue, 15 Sep 2026 10:07:24 +0000
Multiple Instances of SC and data connection regarding trading
View Count: 1192
[2015-11-30 15:40:39]
User94740 - Posts: 333
I currently have multiple instances of sc open and one as the source and the others updating according to the source, but after trying to initiate a trade on one of the so-called copies, I was informed I should connect to the data trade service. Is there something I may have missed regarding the instructions as to how to setup multiple instances?
Date Time Of Last Edit: 2015-11-30 15:40:59
[2015-11-30 19:43:02]
At the current time, trading can only be done from the instance of Sierra Chart directly connected to the Trading service. The other copy/instances can only be used for charting.
The ability to trade from other instances of Sierra Chart which are connected to the instance which is connected to your Trading service, is coming in about a month.
[2016-01-03 10:51:51]
could you please give an update on this issue?
[2016-01-04 01:27:05]
The more questions we get from you, the longer this takes. It literally takes away direct time from our development.
Your account is at 183 posts. This takes a lot of our time.
We have no update at this time. Please do not ask us because it will not help.
Date Time Of Last Edit: 2016-01-04 01:27:38
[2016-01-04 02:12:37]
sorry about the amount of posts, but I am just taking advantage of the great software. Yes, sometimes I find things after posting a message(please excuse), but the software has an immense amount of possibilities and sc has done a great job in understanding the needs of traders. I am looking forward to this functionality, because the amount of markets I trade is quite extensive and when the software starts to lack in response due to the amount of memory: which I must say starts around 800mb, then I have to limit my trading opportunities. I appreciate the info and support and can recommend the software. thx and looking forward to the opportunities!
[2016-02-25 14:10:55]
could you please give me an update? thx!
[2016-02-25 18:51:58]
The development of this is done but it needs more testing and the documentation also has to be completed for it.
The documentation we currently have is here:
Data and Trading Communications (DTC) Protocol Server: Using DTC Server for Data and Trading in Another Sierra Chart Instance
It has been released in version 1372.
[2016-02-25 19:04:53]
We just finished some updates to the documentation now:
So be sure to reload that page.
