Date/Time: Wed, 25 Dec 2024 18:22:01 +0000
Checking study until a flag is on
View Count: 849
[2015-11-30 15:39:16] |
User98049 - Posts: 13 |
Hi Support, 1. How do i run a study again and again, while a flag is on, and than, i am stopping that, until the next bar is comming? 2. Is Sleep function works? 3. Can i use sockets in order to communicate with my other app? Ariel |
[2015-11-30 18:08:29] |
1. Look at using: https://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Variables_And_Arrays.html#scUpdateAlways 2. If you use the Windows Sleep function from an ACSIL study, Sierra Chart will freeze until Sleep has returned. 3. ACSIL was not really designed with this in mind, but you can try and see if this will work well for you. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
